Porter Cable Pad Cleaner for REJEX ?
I did the truck with Rejex last night and have been trying to clean the applicator pad. I used Dawn, but all that seems to do is have it coagulate where I can pick it off, but I don't feel the pad is clean. Pads used for prep work cleaned up nice with Dawn.
Suggestions on cleaning pads used for Rejex?
Former Vendor
http://www.autogeek.net/dp730.html
Often times you need to soak them. Once the pads have dried its much harder to remove the sealant from the pad. This cleaner is citrus based.
http://www.autogeek.net/dp730.html Often times you need to soak them. Once the pads have dried its much harder to remove the sealant from the pad. This cleaner is citrus based.
