Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Need to Remove some Carnuba
Old 09-19-2014, 09:09 PM
Dirty Howie
Dirty Howie's Avatar
Default Need to Remove some Carnuba
I had to have my roof color sanded and paint corrected. My guy did not want to place sealer for a couple of weeks for some paint curing reason. So he would only put carnuba on it temporarily. So now I want to remove the carnuba so I can put a couple of coats of Rejects as I just did to the rest of the car.
The paint is clean and polished. So can I just use alcohol or something else to gently remove the wax. If so Isopropol/rubbing alcohol?
DH
Old 09-20-2014, 05:45 PM
cvm
cvm's Avatar
DH
Ive been told 50/50 H20-alcohol is ok; or dawn dish detergent per zaino will strip wax as well.
Old 09-20-2014, 07:57 PM
z06clif
z06clif's Avatar
Try Dawn .it removes wax
Clif
Old 09-20-2014, 08:16 PM
Dirty Howie
Thanks guys. I don't want to have to wash the car. Just get the wax off the roof panel without making a mess.
DH
Old 09-20-2014, 08:34 PM
cegusa
cegusa's Avatar
You could also go to an auto parts store and get something along the lines of Prepsol or something similar. This type of thing is used as a wipe down before a painting process to remove any waxes or oils. You could probably also use an alcohol/water mix. But not sure of the ratio. I bet if you go over to the detail forum at Autogeek you will find some useful info.
Old 09-21-2014, 01:04 AM
Dirty Howie
DH
Old 09-21-2014, 08:45 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
There are indeed several products that can strip wax (3M Wax Remover / Prepsol / Acysol). You can also use a paint cleansing lotion, like Pinnacles Paintwork lotion. Often times a mixture of iso. alcohol /water will indeed also remove waxes. You are correct in making sure the paint is as ready for a sealant as possible, for long term bonding.
Old 09-21-2014, 09:35 PM
Dirty Howie
DH
To Need to Remove some Carnuba
Quick Reply: Need to Remove some Carnuba
