Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Best tire shine
Old 11-30-2014, 09:00 PM
Red Sleeper
Red Sleeper's Avatar
Default Best tire shine
For me the shinier the tire the better. I have tried several different tire dressing products. Most of them are pretty good. Longevity seems to be about the same. The oily silicone products seem to sling off and get on the side of the car so I avoid them. The milky products seem to be like ArmorAll. They work but nothing spectacular.
Jet aerosol is one of my favorites but cost a lot and doesn't go very far. It also drys completely and stays shinny for a long time.
I have even used clear lacquer on old hot rods. The problem here is it looks good until you try to drive on it. Then you have to remove it completely before you apply again.
I'm looking for a superior long lasting brilliant tire shine that does not sling off. I would like to hear what other people are using now.
Old 11-30-2014, 11:44 PM
outkast6991
outkast6991's Avatar
I like the surf city garage stuff and Wolfgang gel
Old 12-01-2014, 08:50 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
Most of the original "shiny" products are loaded with silicones that can help "bloom" and "damage" a tire over time. It is best to use a tire product that is water-based and some tire dressings will add more gloss as a second application is added. There are also water-resistant dressings which might help in rainy areas.
I like Perls and Opti-coat as two well dressings which look good. They do need a second coat for a shiner appearance but last a week or more in most environments. Both can actually be diluted also as they are quite concentrated. Wolfgang and Pinnacle are others.
http://www.autogeek.net/tire-dressings-protectants.html
Old 12-01-2014, 11:26 PM
Red Sleeper
Thanks, certainly a lot to choose from.
Old 12-02-2014, 08:47 AM
Street Rat
Support Corvetteforum!
Street Rat's Avatar
I use Pinnacle Black Onyx tire dressing and am very happy with the results.
Old 12-02-2014, 12:58 PM
Crusher
Just an Ole Surfer Boy
Crusher's Avatar
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
I love the Zaino Z-16. Doesn't sling and leaves the tire with a natural look not the shinny oily look that I don't like. I use it on all the rubber trim and hoses. My buddy uses it on his textured black plastic trim that some cars have. Looks great and lasts longer then other products I've used.
Old 12-04-2014, 01:36 PM
Timbrr
Timbrr's Avatar
Default Tire Shine
Surf City Beyond Black. Not real shiny but a great look.
Old 12-04-2014, 07:12 PM
kmk56
kmk56's Avatar
I like 303 on my tires.
Old 12-04-2014, 08:17 PM
Red Sleeper
I never heard of this stuff before. Is it like milky ArmorAll product?
Old 12-05-2014, 12:07 AM
leebay
leebay's Avatar
I like Zaino Z-16, I have tried Perl but when driving in the rain my tires turn brown.
Old 12-05-2014, 01:02 AM
Red Sleeper
That sort of happened to me. I had several layers of all different kinds of tire dressing on the tires and you could see that it had a slight brown hue. I used naphtha with a brush and a rag to clean the tires. I wasn't sure if naphtha would work but it did and returned the sidewall to a new tire look.
I just bought a bottler of Turtle wax Platinum high gloss tire shine with wax to see if it was any good. It shines fairly well but oddly looses it shine in about two days even if you don't drive the car.
Old 12-05-2014, 09:03 PM
rsparks64
rsparks64's Avatar
i have never used aerospace 303 on tires but it is great on all black rubber or vinyl trim- also provides uv protection. Some use it in the interior too. I use it under the hood as well. You should get some even if you don't use it on tires.
Search it on here and you will see it gets a lot of praise. If you can't find it locally order from Autogeek or a similar vendor.
Old 12-05-2014, 09:39 PM
Former Vendor
303 is a water based protectant that can be used on many items thru-out the car. It is a great product also.
http://www.autogeek.net/303aerprot.html
Old 12-09-2014, 12:15 PM
chasboland
chasboland's Avatar
me too! just looks the best imho.
Old 12-12-2014, 04:28 PM
bigcypress
bigcypress's Avatar
zaino here , i like the way it lasts and looks .
Old 12-12-2014, 06:38 PM
pikkashoe
pikkashoe's Avatar
If your willing to put some work in, this stuff is the best.
You can coat it multiple times to make it glossier.
And it lasts for months.
http://www.autogeek.net/tuf-shine-ti...rance-kit.html
Old 12-13-2014, 12:38 PM
woodranch
woodranch's Avatar
Chadwick's Triple Play has great tire dressing!
To Best tire shine
Old 12-13-2014, 02:44 PM
Red Sleeper
Hey, this got my attention! This may be what I'm looking for. It may be a while before I try it. I have about five bottles of various kinds of shine that I will use up first.
Kind of pricey but if it last a long time and is shiny it will be worth it.
Old 12-18-2014, 09:54 PM
Red Sleeper
I finally found the picture I was looking for. This is what I'm looking for as far as shine goes. The tire looks wet but isn't. You can even bump up against it and not get dirty. However, it does not hold up well in rain. Multiple coats creates a shinier effect.
Old 12-26-2014, 04:46 PM
WetteVette
WetteVette's Avatar
303 may be more expensive than the other products, but I think it is worth it. Nice, non-oily sheen works great on interior parts, and the UV protection is a plus.
Quick Reply: Best tire shine
