Is use of a clay bar necessary ...
if you're going to use polish, such as Menzerna Intensive followed by Final Finish, prior to waxing? Seems to me like the polish should remove all the things that the clay bar does.
The clay bar cleans the paint and gets it ready for polish. The polish is harder to apply and remove if you skip the clay bar. I thought the same thing years ago and found out it took twice the time to polish when skipping the clay bar step. I tried the nano pad on the porter cable and used the bar for the tight areas. The pad worked great and saved some time.
Some companies (Meguiar's for one) make a "Cleaner" wax
In their 3 step process you use the Cleaner wax, then polish, then wax.
I've tried the plastic bag test (You know what I'm talking about ?) after using the cleaner wax, and my results seemed to be the same as when I've tried the clay bar.
A problem is those embedded contaminates can get stuck in your pads and create worse damage. 30 minutes to clay before a polish is worth it.
Former Vendor
Iron-X and Claying are both quite valid steps in car care, especially for those specializing in each step for the best of finishes.
Wash --) Iron-X --) Clay --) Polish (multi-step) --) Protect
I have been using clay bars since 1996 when a dealer friend gave me a bar to get the "train dust" off a white car that would not wash off. Its always one of my steps when detailing a car.
