Corvette Lug Nut Cleaner Brush and Lug Nut Replacement Heads
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Corvette Lug Nut Brush Cleaner Tool
Keep your lug nuts and your hands clean by using the simple and effective Recessed Wheel Lug Nut Cleaning & Polishing Brush
The Corvette Wheel Lug Nut Cleaning & Polishing Brush allows you to clean recessed lug nuts with minimal effort. The lug nut brush fits over and surrounds the lug nut and with a simple twist, brushes away brake dust and grime instantly. The Recessed Wheel Lug Nut Cleaning & Polishing Brush should be in every detailer's tool box!
Brake dust and oily grime collects around the lug nuts on any vehicle. Before the advent of the Recessed Wheel Lug Nut Cleaning & Polishing Brush, you had to use detailing swabs to tediously clean around lug nuts. The Recessed Wheel Lug Nut Cleaning & Polishing Brush has a round foam cleaning head that surrounds the lug nut to clean it entirely with one quick motion. In literally seconds, you can completely clean all the lug nuts on one wheel.
The Recessed Wheel Lug Nut Cleaning & Polishing Brush cleans wheel cavities from 1 3/8 to 2 inches with lug nuts from 3/4 to 13/16 inches - the perfect size for Corvette wheels. The brush includes an extra foam cleaning head.
Order here: https://www.southerncarparts.com/cor...ut-p-7064.html
Lug Nut Cleaning Tool Replacement Heads Package - Set of three
If you already use the lug nut cleaning tool but need replacement heads, then you are in luck. This packae is sold as a set of three for one great price.
Order here: https://www.southerncarparts.com/cor...ds-p-7065.html
__________________
