Wheel Weight Glue Removal
Just got new tires and seeking suggestions on how best to remove the old weight glue residue from the wheel barrels. Any suggestions?
Former Vendor
I have used a solvent adhesive remover, and some elbow grease. I have also seen others using a polish (paint or metal depending on wheel type). It is easier to work on the wheels off the car.
If you want to do the best you can without increasing the risk of lifting the paint on the barrels, I would use a blow dryer, your fingers and quite a bit of patience. I've even seen some folks try WD40 and have the paint rub away.
I have used just about everything mentioned ever.
Still have very thin residue though. It is smooth but still present. I gave up for fear of doing damage.
Used heat with every solvent I could lay my hands in.
Goo Gone removed it all from my wheels after being on there awhile....the key is to let it soak....scrub and reapply.....I also used a non scratching kitchen sponge.....its a pain in the *** but it works
Thanks for all the input!!
