Best wax/protectant for new clear coated wheels
Hey guys! I just got a new set of Fikse Profil 5's that I've been waiting months for. The centers are their Techni Polished style which has a clear coat applied at the factory. They warn against harsh chemicals with cleaning, which can damage the clear coating, but what would you suggest to be the best wax or protectant for me to apply to keep these beauties looking as good as they do now? Don't have them mounted yet so I think now's the time to get the right start! Thanks for you help and advise!
Jim
Jim
Former Vendor
I would apply a good coating, one of my favorite is currently out of stock but back shortly, called G-technics Wheel Armor. For wheel cleaner, only use P21S. I saw many years of better than new looking uncoated wheels using both on Iforged Swifts.
Thanks for the reply but I see that the application instructions call for wiping down the wheel surface with isopropyl alcohol. How would this step affect the clear coat already on my Fikse's? I've read a couple threads about this product since you suggested it and some others have mentioned it having a strong solvent smell. You mention having it on uncoated wheels, my wheels are clear coated. This worries me. I was thinking more in the lines of a good wax but I'm not discounting this product. Always been a big fan of the Griots and Adams products. Any other advice would be greatly appreciated!
Jim
Jim
Former Vendor
Jim
Jim
The clearcoat on your wheel is much thicker than a layer of clearcoat on paint. The iso alcohol wipe will NOT hurt the wheel and dries almost immediately. (think about this, the average wheel cleaner uses acid and citrus for cleaning) Griots makes a product called Paint Prep that works as well as alcohol as desired.
The smell of these products is indeed heavy and solvent based. Its what is currently needed to keep a ceramic based coating from hardening. It flashes almost immediately upon application. Many people are using coatings on paint and trim without issue and finding the benefits of long term protection.
The reason I offered my personal wheel was that uncoated wheels are almost immediately in a position of degradation from environment. They are also quite susceptible to damage from acids and other harsh products. Neither P21S, nor Gtechnics Wheel Armor harmed the wheels and infact helped reduce need for constant polishing and wear. Griots also makes a great wheel cleaner but wont need to use it often especially if you choose a wheel coating.
Thanks Killrwheels! I appreciate your advice. I think I'll try this route but definately test a small area first. I've heard horror stories of people putting the wrong thing on a set of clear coated Fikse's and destroying the clear coat on the faces. The barrels on the other hand are uncoated so no worries there. My Z is not a daily driver, only a fair weather cruiser so longevity should be fine. Again, thanks for the advice
Jim
Jim
Former Vendor
Jim
Jim
As for testing a small inconspicuous area first. Great choice, its valid when using any material on a new surface.
Absolutely excellent advice by Killrwheels, in my shop we use 2 coats of Zaino Clear Seal. The Polymer withstands the heat and provides a slick surface to allow the dust to slide off. I had Fikse FM-10's on my 98 Vette and CCW's on my C6. Used Clear Seal on both and really did not have to touch them, other than a rinse when i washed the car.
