Newbie polishing questions...using what I already have...
In a few days (after I let my clear coat cure) I will be wet sanding and polishing my targa top.
Has anyone used a random orbital sander with some sort of polishing attachment to get this kind of work done? I ask because I have a 5" ROS from Harbor Freight and I was hoping I could use that somehow for the polishing end of the job. Looking for some advice as to what to use from a pad/attachment standpoint (it's a hook/loop unit)...also from some general direction on how to polish and buff.
I don't want to go out and put $$$ into polishing equipment that I would probably never use again.
If there is no good way to use what I have then I'll be doing it by hand...which brings up another question: if I DO end up going by hand should I polish in straight lines or in a circular motion like a buffer would? Does it really matter?
I'm pretty much a newbie when it comes to doing this kind of work so any input would be appreciated.
Thanks!
Thanks!
Former Vendor
Thanks!
Thanks!
I would highly suggest reviewing the areas on our forum in relation to Mike Phillips and Wet-sanding and polishing. If you cannot find specific advice, please consider posting. Mike Phillips is highly regarded as one of the best in the industry.
http://www.autogeekonline.net/forum/
