White marks on door panels
They look like they could be from chalk or something. They are not, but best way I can describe them right now. Simple Green didn't work, warm water didn't work & 303 protectant helped some, but once that wears off, they will show through again.
Anyone else have these marks on any cars & how did you get rid of them?
Here are a few threads about this problem.
https://www.corvetteforum.com/forums...t-is-this.html
https://www.corvetteforum.com/forums...or-panels.html
https://www.corvetteforum.com/forums...ith-ebony.html
Former Vendor
It does have something to do with the composition of the materials in the C6 model. I easily contained mine by cleaning with a light APC and damp towel. I then sealed the interior with Ultima's Interior Sealant. If you choose to use another protectant, follow the reapplication on a normal schedule and you should avoid the white chalky appearance.
Former Vendor
I use Blackfire as its designed for automotive use and doesn't sudz up the way some can. Remember to use it on a damp towel and just enough to lightly clean the surface. (test other APC's in a small hidden area first, to assure no color transfer)
http://www.autogeek.net/blackfire-interior-cleaner.html
Clif
I don't know if you looked at the 3 links that I posted a few weeks ago, but it seems like post #19 from:
has the best answer. I wonder how similar the GM products are to 303 and other products that are out there? Most likely the GM products are pricey.
I keep a spray bottle of distiller water and one of the micro fiber mits specifically for this purpose. A wipe down of the door panels and dash every couple of car washes and the white spots are abated. I am not a fan of dressings for the interior.
