Spray wax over a Carnuba?
5th Gear
I am planning on detailing my 2013 vette with polish, sealer then Carnauba. Question is can you use an occasional spray wax over a Carnauba wax?
Former Vendor
http://www.autogeek.net/quickdetail.html
5th Gear
Yes indeed .... look for a good spray wax with 'nuba (Optimum, Pinnacle, etc) and keep that delicious wet look alive longer. As an added benefit you don't need to do a traditional wax as often.
Glad to hear..............thanks for the input!
I had the same question. Can I put a Spray Wax, over a Carnauba Hand Wax... I was told by someone, that you shouldn't do it...
Former Vendor
Some spray waxes are synthetic based (sealants) and some suggest they streak or incompatible with 'nuba based waxes. Using a carnauba based spray wax should provide no harm and can actually boost the waxes durability. Most manufacturers design sprays that are compatible with their waxes as a valid choice also.
