weather seals maintenance
Other than Aerospace 303, what else is out there that's "better" ? Thanks. (no matter what type of towel/applicator I use with 303, I can't find a way out of the streaks as its being applied).
Former Vendor
Adam's SVRT works great on all Vinyl, rubber & tires!
How do you make the industries best trim and tire dressing even better? You eliminate its only weakness by making it water repellent! This amazing new product will amaze you each time you use it.
That's right!! We've taken our extremely popular Vinyl, Rubber, and Tire dressing and eliminated the only complaint any of our customers ever had about it. Now instead of Adam's VRT Tire Trim Dressing washing away with the rain or coming off each time you clean your car the NEW Adam's Super VRT Tire & Trim Dressing actually BEADS AND REPELS WATER!!
Advances in polymer technology allowed us to keep the same amazing water based, low gloss, formula and make it water proof. The special additive allows the product to stand up to multiple washings, hundreds of miles of rain driving, and it even reduces surface tensions so much that water will literally roll right off of your trim and tires.
Sound too good to be true? Check out our latest video to see this amazing new product in action
NOTE: Adam's Super VRT Tire & Trim Dressing is for exterior use. For interior leather, vinyl and plastic use Adam's Leather & Interior Conditioner or Adam's Total Interior Detailer
http://adamspolishes.com/shop/exteri...-vrt-16oz.html
8th Gear
1z gummi pflege has been used by pro detailers for many years to treat rubber door seals. It's designed specifically for this purpose and is also relatively cheap given how long a bottle lasts.
Former Vendor
If you like 303, you might like the new design for seals.
There are indeed many other items available for this area also. I too use 1Z Einszett most often. Its water-resistant and appears to last quite awhile. One hint, remember to allow the area 10 minutes or so to dry before closing doors or windows. Consider buffing the area with a MF towel to remove any excess also.
I am after the best of the best, the weather seals on my car are expensive to replace (if you can find the parts) and want to prolong them for as long as I can. I'll try a few suggested here, (thanks again). I find it a little tricky getting the product on the seals only without touching the surrounding paint.
That is the beauty of Lemon Pledge. Spray it on the weather stripping and don't worry about the paint in the jam. Wipe it off with a slightly damp micro fiber rag. Looks great and is so easy/fast to do you can do it every wash.
Better than 303 any day.
Former Vendor
