Learning how to use a rotary buffer
I finally met my match with a 94 C4 with a lot of deep RIDS and neglect from dry rubbing wipe downs. It still compounded and polished out to a high overall gloss, but may deep scratches remained. I think it may have even needed wet sanding on a couple of panels.
I want to get a rotary, but how do I mitigate the steep learning curve for a home-gamer like myself who has never worked in the auto body trade?
thoughts:
-use a foam pad for starters
-practice on sh!tbox cars
-paint thickness tools ?
-a detail clinic that would offer some hands on (?)
Has anybody learned this art without inflicting too many mistakes on nice cars?
thoughts:
Former Vendor
correct .... a rotary all builds up and transfers a lot more heat. It will cut faster (correct paint) and extra care is needed especially on lightly painted areas and corners. With a little care, it can be a very valuable tool.
Update---Got a pawn shop Black and Decker 6138 which is an industrial line of B&D tool that is now more commonly known as the Dewalt 849. It was still made in the USA back in 90-something. It's a little older, but good to know all the 849 spare parts are the same. I even found a velcro backing plate on another rotary tool that they threw in with the deal. I just couldn't justify going all in for a new one at $200. Hoping to test this out on something (not my stuff, lol) soon.
^^^ Yes it does! And that is the combo that I use a lot on my stuff, but have been wanting to try different things
I watched the you tube videos by Junkman 2000, used the supplies he recommended and his process. I am amazed at how easy and well it works, as I had never used a buffer on paint. My paint is so bad that I skipped the clay bar, and went right to the compounds.
Only skip claybar if paint is in good shape. You made your job harder.
Just to clarify; I already have a porter cable DA and the Flex as well. The reason for the rotary is that I have been running into situations where it might save me time or provide a little more heat for deeper scratches.
I may have a victim I can practice on- it's a 92 Toyota MR2. The only problem is it was made before toyota started using clear coat paints so it's gonna turn my brand new $12 rotary foam pad red.
You still need to do it, you are pulling all the contaminates into your pad and scratching the paint with it. So the pad is trying to polish and scratch at the same time. You are also putting scratch agents into your pad that may never come out.
There is a reason you do the sandwich bag test on your hand before you start.
Former Vendor
There is some serious paint polishing that can be done with orbitals. It comes down to using the correct polishes and pads. Microfiber cutting pads often can equal the outcome of rotary polishing when done properly .... just another option versus buying another machine.
http://www.autogeek.net/microfiber-buffing-pads1.html
I would respectfully disagree. Put your hand in a plastic sandwich bag and gently rub it over a horizontal surface of the car. In 99.9% of cases it will feel like sandpaper under your fingers. These are the surface bonded contaminants you are feeling and they need to come off before you polish. this is why you always clay bar first. It also gives you a chance to inspect every square inch the surface before you begin to polish.
