Detailing Plan, any suggestions?
99 Black FRC 95k miles
1. Power wash to get the dust/dirt rinsed off
2. Wash with Pinnacle Liquid Rinseless wash
3. Speedy Prep Towel - Fine
4. Meguiar's 105
5. Meguiar's 205
6. Menzerna Power Lock
Porter Cable 7424XP
Lake Country 5.5 Inch CCS Pads 6 Pack
2x Orange for the 105
2x White for the 205
Blue or Red pad for the Menzerna PL wax
Six months ago, used Iron-x and waxed with Menzerna Power Lock.
Should I do a iso-alcohol wipe down between 105 and 205?
Should I not do a rinseless wash and go with a Meguiar's gold class or a Meguiar's All Purpose Cleaner?
Am I missing anything?
4. Meguiar's 105
5. Meguiar's 205
Porter Cable 7424XP
Former Vendor
I don't see the need for an iso wipe-down between the polishing steps. If an iso wipe is desired, it should be between the polishing and sealant stages. That way any polishing oils are removed and the sealant can cure for the longest protection.
As for the washing stage, either rinseless or standard wash will work. With a standard wash you can move directly to the clay prep towel after rinsing off the soap while finish is still nice and wet.
Have you tried to apply the Powerlock by hand ?? Its pretty thick and usually very easy to apply by hand or buffer. Just remember a light, even coating as possible. Great looking sealant !!
St. Jude Donor '09
4. Meguiar's 105
5. Meguiar's 205
Porter Cable 7424XP
4. Meguiar's 105
5. Meguiar's 205
Porter Cable 7424XP
Black paint is a bear, good luck....
Former Vendor
Simply, for a good portion the notable difference in polishing is often enough to move to the next step. While those that want to polish as perfectly as possible with each polish (step), it is a great idea to wipe off any polishing agents and fillers to make sure the paint as close to perfect as possible. They then can move to the lighter polish or pad (or both) in order to finalize the finish and remove any remaining light marring.
cmonkey713 (11-24-2015)
