Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Emblem removal
Old 12-02-2015, 09:35 AM
JetstreamGS
JetstreamGS's Avatar
Default Emblem removal
Want to replace rear cross flag emblem on my C6. Body shop can't guarantee no paint damage. What's the best way to do this?
Old 12-02-2015, 09:43 AM
0Adam's Polish
Former Vendor
Adam's Polish's Avatar
St. Jude Donor '15-'16-'17
I always use a hair dryer to heat up the badge then take a piece of fishing line in behind the badge and saw back and forth. After the badge is off you can peel off residue like you would a command strip (like you would hand a pic on the wall). You may need to use Goo Gone to get it all off..... Hope this helps!
Old 12-02-2015, 07:24 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
We use dental floss doubled or tripled over to remove dealer emblems. Then a quick cleanup with a solvent or Wd-40. Just remember that some emblems (like the front emblem on C5/C6) have a pin in them that goes into the body panel. Takes a little more time to remove it, and need to replace with the correct emblem which allows it to be aligned properly.
Old 12-04-2015, 09:20 AM
JetstreamGS
Thanks fellas. I believe the rear has a pin too I will have to check the replacement emblem.
Old 05-23-2016, 08:47 PM
JetstreamGS
Well after spending two hours flossing this damn thing, my fingers are all cut up and fingernails bleeding and sore and I'm only about halfway done! Not a happy camper lol!!!
Old 05-24-2016, 09:20 AM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
Did you use a hair dryer first to help release the adhesive?
Old 05-24-2016, 12:23 PM
Scuba Ghost
Scuba Ghost's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
1. Hair dryer
2. Dental Floss
3. WD-40
Old 05-24-2016, 12:27 PM
ronkh57
ronkh57's Avatar
Wear work gloves
Old 05-24-2016, 01:45 PM
JetstreamGS
I did, didnt seem to help much.
Originally Posted by ronkh57
Wear work gloves
Good idea, was wearing medical gloves that didn't offer much protection.
Old 05-24-2016, 05:28 PM
Former Vendor
wow ... not sure I would use that dental tape between teeth. Sounds like some stubborn glue, actually.
You can saturate the emblem with a little water or a solvent to help loosen the glue, then carefully go back to dental floss.
To Emblem removal
Quick Reply: Emblem removal
