Glass cleaning with steel wool
I would start with glass cleaner, clay bar, then car wax on, as first step that is no aggressive.
Then you could always step up with something more agressive, as grit paper .
I've heard some people use super fine grit paper on windshield, but never seen result, so i can advise you about it.
Anyway I think that glass cleaner, clay bar plus wax will work pretty well for wiper trails
There have been posts here on the Forum on using steel wool to clean the windshield. When using steel wool always use #0000 grade so you won't scratch the class. Also you should use a lubricant with the steel wool like quick detailer or glass cleaner, it provides some lubrication and makes things much easier. You would only use the steel wool method in severe cases of windshield cleaning. I would start with clay bar and then proceed to a glass polish and then to the steel wool is the glass does not look the way you want it. After the glass is clean coat with a glass sealer to keep it nice and slick so contaminates are less likely to stick making it easier to maintain.
Be better off with Bronze wool as it is softer.
how about that professional glass cleaner that you use to get your showerstall clean. I got some from the glass place when I had my windshield replaced. You can also try "soft-scrub" by Clorox.
Clif
Clif
Former Vendor
We offer a couple items that work well at cleaning up glass and wiper trails:
http://www.autogeek.net/dp515.html
http://www.autogeek.net/dia-glasswork-restorer.html
http://www.autogeek.net/griots-glass-cleaning-clay.html
If you need something more abrasive, use this with great care:
http://www.autogeek.net/carpro-ceriglass-polish.html
Good advice...
I'll point out that some side view mirrors, especially on the modern cars, are actually plastic with a mirror coating on the outside surface and it can wear off.
I can't quite tell what our 2008 ZR-1's mirrors are made of, but I have seen other makes and models use plastic, likely because it's less expensive, lighter weight, and also allows for added features like heating elements and built-in turn signals.
I prefer steel wool to clean my windshield as it's quick and easy, cheap and nontoxic
