Cleaning around C7 Tail Lights
Received 3,439 Likes
I notice that a lot of dirt gets trapped around those crevice areas in and around the tail lights. I have been using a soft bristle brush. Is there a better method for this? Thanks.
Former Vendor
http://www.autogeek.net/boars-hair-c...ing-brush.html
This is a great, and safe, brush to use when washing. It works great in corners, around lights, and other areas. Just add a little soapy water.
Because of the aerodynamics of the booty of the Vette, you will often see more dust/dirt in this area. Clean carefully to avoid marring, and use a good sealant or coating that doesn't attract and capture dirt. A good anti-static spray (like those from Finishkare) also can help some too.
I use one just like that with the soft bristles.
