Buffer trails
Buffer trails
I need some advice or expertise, someone recommended that I get a Groits DA buffer and get Meguires M105 and M205 to remove clear coat scratches and minor swirls, the buffer created buffer trails and marring, the M105 is a very abrasive compound, and left really bad marring, then I hit it with the M205 this helped as being a good polish, but what kind of pads do I need and a polish to get rid of the buffer trails and marring. I spent over $200 on the buffer and really expensive compound and polish which someone recommended to me. Please help
Grand Poobah
*EDIT*
Make sure to prime your pad.
So do I use the M105 on orange then M205 on black? What do you mean make sure to prime your pad. Just wondering if this will take away my buffer trails and scratches in the clear coat. Thanks
Grand Poobah
How to prime the pad:
Pro Mechanic
Received 3,952 Likes
Don't know what size the pads for your machine are, but you could also check out Adam's Polishes for pads, polishes, and videos which explain how to properly detail your vehicle.
Adam's Polish (04-05-2016)
Former Vendor
105 is indeed an aggressive swirl remover. It also uses non diminishing abrasives meaning it cuts at the same level from start to finish. Generally speaking, you go to this polish and some thing like an orange Lake Country CCS pads for swirled paint. You make several passes working a small area no bigger than 1/2 a panel at a time. You use full speed on the buffer and enough pressure but not enough to stop the pads movement. You buff off the polish and measure the success versus the other 1/2 the panel. --becareful on edges and corners, consider taping trim.
Once the panel has been polished to a notable level, you move to a lighter abrasive pad and the 205 (same abrasive, continual cutting). This will remove lighter marring (little scratches) and amp up the gloss and reflection. I personally prefer a polish with diminishing abrasives like Menzerna 085rd which breaks down over its use and offers a very high gloss rating too. Its really personal preference as both are considered finishing polishes.
One of the users warned that you should prime the pad. This is getting just enough polish on the pad in advance of polishing to avoid having a bare pad touch paint. Once a pad is primed, you will use only a couple small dime size dots of polish on the pad or making a small then x pattern. If the polish appears to be drying to soon, consider a light spritz of water or pad conditioner.
What pads and color pads (abrasive levels) did you purchase ???
Yes pads are going to play a big part in correction work. Maybe you didnt even need to use the 105. Also are you cleaning or changing out the pads? Was the car clayed before correction?
Chemical guys hex logic orange pad. Then finish with a black pad.
Former Vendor
You certainly can use multiple stages to remove the marring from a more aggressive polish as needed. Perhaps using a less aggressive pad with 105 might help also. The idea behind polishing is simple, start light and move heavier (more aggressive) only as needed.
I use 105 0n scratches and 205 on swirls. 105 can cause imperfections in paint that Need a less aggressive polish. 8 use orange lake country MFG on both. Black for glaze. I hope I am not doing it wrong.
Former Vendor
Consider getting a small handheld flashlight ... I use a Fenix with 800 lumens. Shine on the panel and look at the area off axis. If you see very light faint scratches you indeed need to move to a lighter pad for true finishing.
I have never stepped down pads with cutting, thanks I will look at that, I cut with same pad grit just changed to new pad and step down polish. I always glaze with finnish pads and hand wax. I have PC dual action what pads would you recommend? I still have a supply of 105 and 205. And lake country MF medium cutting and finnish pads (orange & black).
Former Vendor
http://www.autogeek.net/hydro-tech-foam-pads.html
