Can this be removed?
Had a guy use one of those rubber wheel on this and buff but, next day this shows. Can this be removed my moldings started bowing so I removed them<br ><br >
Rubber wheel ???
Former Vendor
If you removed the body side moldings from the car, you likely have some light discoloration against the areas that saw sun and UV rays. You will also see adhesive marks and perhaps even hard water marks where it sat under the molding and on the adhesive.
I would first consider a good wash, claying and paint cleansing to assure any remaining sticky is gone and doors are ready to polish abrasively. You might need to consider a light wet sanding but I would not go to that length until polishing is done right. For best results do not spot polish, but polish the entire area to try and blend it.
Let us know how it turns out and if something else is found to be the culprit.
