Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Can You Remove Swirl Marks on Polished Wheel ?
Old 05-19-2016, 02:04 PM
b4i4getit
b4i4getit's Avatar
Default Can You Remove Swirl Marks on Polished Wheel ?
I have a polished wheel that developed some swirl marks when I wiped off some stubborn crud after I washed. Now I have some fine swirl marks in the clear coat. Is there any product that is safe to use on a clear coat wheel that will work ? Thanks.
Old 05-19-2016, 07:47 PM
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
If the wheel is clearcoated, you can treat it just as you would paint. So you would use a paint polish to help remove the swirls and you then can protect it by waxing, sealing, or coating. I would suggest using a machine as the clear-coat on most wheels is quite thick and durable.
It is pricey but a new tool from Rupes, Ibrid Nano, would be perfect for wheels ....
http://www.autogeek.net/rupes-ibrid-...hort-neck.html
Old 05-20-2016, 09:20 AM
b4i4getit
b4i4getit's Avatar
Thanks. I was hoping someone had some experience using some type of scratch polish and could recommend.
Old 05-20-2016, 12:23 PM
Jim D.
Jim D.'s Avatar
If you want to work by hand, try a quality scratch remover and see if that does the job for you.
Mothers California Gold Scratch Remover is excellent on wheel coatings.
Autogeek sells it, and I'll guarantee it. Email me if it doesn't work for you.
jimd@mothers
To Can You Remove Swirl Marks on Polished Wheel ?
Quick Reply: Can You Remove Swirl Marks on Polished Wheel ?
