product for painted wheels? GS gray wheels
I have the gray painted wheels on my Grand Sport. What do you guys like to use on these to keep them clean and low maintenance? Thanks
Former Vendor
Painted wheels can be treated just like other painted areas. Wash well, clay as desired, paint polish as needed, and then seal or coat your wheels to protect and make cleanup easy. Never work on wheels when hot !
Now here are some items that are must haves for wheel care.
1. Griots, P21s, or Mckee 37 Wheel cleaner. (All very safe)
2. Speedway Wheel Brush or Wheel Woolies
3. G-Techniqs Wheel Armor Coating
Former Vendor
Adam's NEW Wheel Cleaner is the ultimate way to remove stubborn brake dust and metallic contamination from your wheels. The new, thicker formula clings to wheel surfaces and allows the european derived formula to melt away the stubborn brake dust commonly left behind by many of todays high-performance braking systems. The color changing formula lets you know its working, turning to a deep purple as it activates and does the hard work for you.
Best of all Adam's Wheel Cleaner is safe for most wheel finishes. So whether you have factory clear coated wheels, aluminum, or paint the highly effective cleaning solution will remove the stubborn brake dust, but won't harm your wheels. Saturate the wheel with Adam's Wheel Cleaner and allow the color changing formula to activate.
http://adamspolishes.com/shop/exteri...l-cleaner.html
Adam's Polishes is the Officially Licensed Car Care Product of Corvette & Camaro.
