Paint Preparation before applying a polymer wax
What have you used to remove the old wax from the paint. I have heard that Dawn soap may remove wax, however is another method available. The directions on the poly wax bottle states that the old wax should be removed before applying to insure a long life for the poly wax. Otherwise, when the old wax breaks down under the poly wax coating, it's coating life is shortened.
To some degree I think the dish soap is more myth. I too am guilty as I will do a Dawn pre-wash with a cap full of APC . There are several products on the market that you can choose from. You will more than likely see them as paint cleanser's. I have many ,many times used CarPro Eraser. A nice wash-clay and polish should remove old as well-especially if a coating previously applied -polishing is the way to remove.
Go to autogeek and check them out. What seems to be a well thought out and budget friendly line is their McKee 37.
The following 2 users liked this post by yamabob:
ETHYL (06-03-2016),
Killrwheels@Autogeek (06-07-2016)
Former Vendor
For nice paint, I often suggest using a cleaning lotion to prep, one like Pinnacle Paintwork Cleanser or P21S:
http://www.autogeek.net/wax-remover.html
ETHYL (06-03-2016)
I am not a fan of using Dawn on my car. As a detergent, it does nothing good for plastic and rubber trim, and over time, I think it will dry those items out.
Former Vendor
I too prefer to use a dedicated paint cleaner and leave dishwashing liquids in the home. There is no proof that Dawn removes all of a wax, it does remove the oils and beading, but may not even dent a fully cured sealant.
