Do Wheel Woolies Scratch?
Any thoughts/opinions on this?
new C7 black machined aluminum wheels >2k miles. Had detailer coat them with Cquarttz @ 450 miles.
Maybe i'm being picky but i noticed swirls in the black part of the wheels.
Use Uber mixed in waterless ratio and also pre spray.
Woolies shoun't scratch (unless they pick up crap and you're rubbing it against wheel)
Rinse periodically was you clean.
Could've been the installer, who knows.
They're very fine swirls like you would see in paint.
Make sure wheels have good amount of soap/cleaner on em and the woolie is wet w soap solution
Killrwheels@Autogeek (08-08-2016)
Former Vendor
Brake dust can be abrasive, infact, rubbing anything against any finish "could" be abrasive. It is best to use a good, safe, wheel soap and use it liberally. Don't use a dry wet, add water before using. Also use good care when drying. Rubbing a towel on the rim could also cause swirls. I spritz mine liberally with a detail spray and try to blot or lightly wipe when needed.
Myself, I would try a rinseless wash AND pre treat wheel with rinseless diluted to qd strength, then use you wheel woolies as well as garbage micros.
Except the part about wheels only getting done once per month (i clean the car once per week), that is the method i use.
ronkh57 (08-13-2016)
Former Vendor
http://www.autogeek.net/waterless-ca...-products.html
