grease/tar spots on inside of wheel
I have some grease/tar spots on the inside of my polished wheels. They smear but they wont come off. I scrubed the hell out of them and tried simple green but no luck. Please help me out. thanks
Re: grease/tar spots on inside of wheel (Hokie)
If you have clear coated wheels, try Castrol Super Clean Degreaser or Greased Lightning for the grease. WD-40 or kerosene will take care of the tar. I always use a piece of plastic (like the plastic from a plastic file folder) to remove the big globs and then use solvents to finish the job.
1 Post
Cruise-In III Veteran
St. Jude Contributor
Re: grease/tar spots on inside of wheel (stevenll)
If your wheels are clear-coated you should treat them like your paint. Try some clay or a Tar Remover, such as Stoner's Tarminator.
