Washing with hot water?
Would it be ok to wash with a bucket of hot water?
Pro Mechanic
Received 3,938 Likes
Although I would not use water near the hot range on an otherwise very cold surface of a Corvette. I don't know if it would crack the paint or the composite but I would not want to be the one to find out.
ronkh57 (12-27-2016)
Former Vendor
I have not heard of any formal actual positive results from using hot or warm water over cool water. What I can offer is in South Florida our water is always warm. I supposed its about personal comfort mostly .... as with anything, handle with care.
Up here in Washington, during the winter, sometimes we'll have stretches of very dry, but cold weather. When possible I'll use Poorboys Spray and Wipe in a garage with a space heater on, but that's not always possible or a good idea depending on how dirty the car is.
Thanks for the input. I do like the idea of hot water stripping off wax though. I think I'll use warm water next time.
i've heard of people breaking car windows trying to deice them with warm water , this was 60 years ago . man i worked with had rear window of his new 1954 ford shatter when he backed car out of garage one cold morning . . . peace
I wash my C7 with very warm (as hot as it'll come out of the tap) water in the winter. If I don't the water is too cold on my hands. I have Raynaud's Syndrome (http://www.mayoclinic.org/diseases-c...n/CON-20022916) and I cannot allow my fingers to get chilled. The result of chilled hands is extreme pain.
So, very hot water it is. In the summer I use bucket and hose temp water which is quite cool. I wax the car everytime I wash it with Meguiar's tub style wax.
I've never noticed the wax stripping with either hot or cold water. I suspect that if the water is hot, but not so hot you cannot hold your hand it in, it would be fine!
Hot is a relative term. The surface of your car gets far hotter than water you can safely submerge your hand in.
"Even though a water temperature of 110° F is ‘relatively-safe’, exposure can be painful; the human pain threshold is around 106-108° F." quoted on http://www.1800anytyme.com/blog/how-...is-too-hot/27/
I use warm water year around and when its cold outside I wear elbow length gloves I got at Northern Tool.
I'm also in Washington and hand wash my car in cold temperatures. Your hand will freeze for a minute but will adjust quickly and be fine. It'll make you tough!
I did use this drive through brushless wash recently (Karmichael's) that sprays the underside of the car. I use it to rinse any salt that may have got under the car. It's a piece of mind. My car was clean too, it worked well. Even the wheel wells were cleaned good.
As for your question, I'm sure you'd be fine with some warm water. Give those hands some comfort!
Let us know how it works
