Ceramic Options
Ceramic Options
Briefly looked through the front page of this sub forum and didnt see many threads about ceramic coatings. I have been using zaino but would like to try a ceramic.
What are yalls recommendations? I have a crystal red c6 and my goal is longevity/making cleaning week to week quicker.
I can follow up with questions and do some research once I get some ideas. Thanks!
KGS365 (02-05-2017)
Ease of use and looks-try Wolfgang Uber. There are many good coatings to choose from.Before applying any coating you want to polish the defects to the best you can.If not they will be trapped under the coating. Simple maintenance,and a period top off canyield maximum life out of your coating
ronkh57 (02-05-2017)
I don't know why you would not want to polish first. Surface contaminates should be removed. In the very least a mild clay and use a paint cleanser such as Car Pro Eraser to remove any wax /sealant.
People always say Dawn. Wax and sealants are meant to protect against UV and mild chemical damage. While it may lessen the effects of protection( and beading). I would not count on Dawn alone to remove old LSP's. An APC would be a better choice. You want the paint to be a free from anything for maximum bonding-no different really than a wax/sealant. Improper prep is the reason a lot of LSP's don't last as long as they should for people
I did my Crystal Red '08 over a year ago with DP coating(I think DP is now called McKee 37), and I did the TTA over two years ago with Duragloss Enviorshield. I don't notice any deterioration in the finish on either one. I go over the car with a detail spray every now and then between washes. As mentioned above, preparation is the key to any good finish.
image_0a6ff694d2f500a60d834eaa463986868a 1b6ab5.jpeg[/IMG]
Received 1,031 Likes
St. Jude Donor '09-'10
McKees Paint Coating is priced right; easy to apply
WG Uber Ceramic a bit pricier but very easy to apply
Kamikaze Miyabi is a bit less $$ than WG Uber Ceramic and very easy to apply
Virtual cornucopia of coating choices, some easy to apply, some require more attention.
Definitely worth it unless you enjoy cleaning your car as 'therapy'; once coated, maintenance goes down considerably.
ronkh57 (02-06-2017)
Former Vendor
Check out this video on our New Ceramic Paint Coating.
After watching feel free to ask any questions.
https://www.youtube.com/watch?v=YeUT...ature=youtu.be
I never understood "ceramic" coatings. How can any ceramic be flexible enough to use on car panels that flex?
And if the product dries as hard as a ceramic then how can you use the same towel to wipe it down? Why wouldnt the small particles of ceramic on the towels surface scratch the finish?
Pro Mechanic
Received 3,938 Likes
http://adamspolishes.com/paintcoating
http://adamspolishes.com/ceramiccoating
http://www.detailedimage.com/Ask-a-P...h-is-too-much/
Gyeon MOHS description mentions flexibility:
Gyeon Mohs is an easy to apply ceramic coating that adds a durable layer of protection to your paint! If you are looking to show off your paint without sacrificing durability, but simply do not have a ton of time to devote to detailing, paint coatings could be your answer. Gyeon Mohs is pretty easy to apply and comes with simple, yet detailed instructions within the package. Each added layer will improve overall durability, gloss and scratch resistance. In order to achieve the very best results, Gyeon recommends applying 2 layers, 3 layers at the absolute most. The hardness of average car paint is approximately 3-4H and Mohs will add another layer that is 3-4H! This dramatically improves your vehicle's ability to resist environmental contamination, swirls, RIDs, etc. Mohs however is not "too hard" and still reacts to the changes in the environment such as temperature and humidity. This allows the coating to be "flexible" in a way, meaning that even though it is hard enough to protect, it is still soft enough to not develop micro-cracks that can hurt looks or longevity. Once cured, Mohs will easily last up to 12 months or 12,500 miles and the hydrophobic qualities will have you standing back to admire the tight uniform water beads. If you are looking for a coating that will wow you with looks and durability, the Gyeon Mohs may be the one you should try!
ronkh57 (02-08-2017)
Ceramics are classified as inorganic and nonmetallic materials that are essential to our daily lifestyle. Ceramic and materials engineers are the people who design the processes in which these products can be made, create new types of ceramic products, and find different uses for ceramic products in everyday life.
Ceramics are all around us. This category of materials includes things like tile, bricks, plates, glass, and toilets. Ceramics can be found in products like watches (quartz tuning forks-the time keeping devices in watches), snow skies (piezoelectric-ceramics that stress when a voltage is applied to them), automobiles (sparkplugs and ceramic engine parts found in racecars), and phone lines. They can also be found on space shuttles, appliances (enamel coatings), and airplanes (nose cones). Depending on their method of formation, ceramics can be dense or lightweight. Typically, they will demonstrate excellent strength and hardness properties; however, they are often brittle in nature. Ceramics can also be formed to serve as electrically conductive materials, objects allowing electricity to pass through their mass, or insulators, materials preventing the flow of electricity. Some ceramics, like superconductors, also display magnetic properties.
Ceramics are generally made by taking mixtures of clay, earthen elements, powders, and water and shaping them into desired forms. Once the ceramic has been shaped, it is fired in a high temperature oven known as a kiln. Often, ceramics are covered in decorative, waterproof, paint-like substances known as glazes.
Are these coatings ceramic or not?
Corvette Enthusiast
My understanding, the coatings themselves are not made of ceramic (like tiles are). But are identical to the coatings USED on ceramics to keep them looking nice (like the coating you'd have on that ceramic tile). They are basically very durable "hard" clear coats, they are usually polymer based.
I am no scientist and might suggest speaking with someone like the Dr. from Optimum. They are often regarded for bringing one of the first coatings to the consumer and professional market in the US. I know that coatings are often described as "ceramic based" or "glass based" in the past. I think of them more about the hydrophobic benefits they offer over traditional waxes and sealants.
As for a question poised earlier in the post ... several coatings, like Optimum, are quite durable and don't wear off quickly. Sometimes they are called semi-permanent in nature. Anything less than abrasives will not remove all of their makeup on a cars finish. So ... as will anything that is going to be with your ride for a very long time, you should properly prep the paint before a coatings application. If paint is in very good condition, perhaps that means using a paint cleansing or prep product. Others will need polishing to correct paint and bring out the true finish for wish you want to coat and lock in.
