Tips on buying a power washer?
Tips on buying a pressure washer?
What should I look for?
I have two pressure washers--one gas, the other electric. The gas-powered washer, I think, makes too much pressure to be used on a car--3500 psi. The electric one is a 1700 psi. This seems to be more practical for auto use and far less likely to cause damage than the high-pressure gas model.
Zero_6 (02-11-2017)
I have an electric pressure washer rated at 1700 psi. The mist mode is fine but not when I switch to other mode which is pretty much useless.
When I was looking for a pressure washer I wanted something that won't hurt the cars paint or finish but could still clean a house or driveway. I've used electric ones before and for cleaning concrete it took forever and didn't do that good. I ended up buying a Generac 6602 after reading several articles and reviews. It has an adjustable psi from 2000-3100. Works great for the cars, I use the Adams foam cannon.
I have to say it's a lot more fun to wash the vehicles now. I washed all 3 this weekend and a buddy used it on his camaro.
and you can see my neighbor's c7!
I just placed an order for Adam's Foam Cannon with the strip wash for $79. It should be here in a few days. I can't wait. Thanks for the info y'all.
Received 1,867 Likes
St. Jude Donor '15
yes it's plenty on the lowest setting. The only time I've turned it up was when I was blasting rubber out of the wheel well from the track. I don't own an electric but I've used them this was way better. No power cords a lot more pressure.
