California Blade
I have used the water blade, and it works well.
After I blade off the water, I use microfiber "waffle" towels to dry.
I have heard some people are worried about the water blade scratching the car...I haven't noticed a problem, but I share the concern.
I used to use a leaf blower but now after a month my hand and finger is still numb
Originally Posted by Jake T
I use a leaf blower. It's non contact and very efficient.
It seems to work ok but I have a hard time dealing with the horrible screeching noise it makes. Sounds like it's doing something awful to the paint.
Well no more leaf blowing the car for a while and
No more detailing for a while per doctor's order. All of this probably contributed to the needle feelings I have in my smallest finger with numbness.
1 Post
St. Jude Donor '05
I have used the Water blade, waffle weave and end with an leaf blower with nylons at the end of it. Never had a problem. Just ensure the blade is wet and cleaned after each swipe.
Location: Ponte Vedra Beach / London State: Dazed and confused
The best-known brand (The Original California Water Blade) is made of medical-grade silicone so it should not scratch. It can be used to remove water after washing the vehicle without causing scratches by applying very little surface pressure with the blade, wiping with long strokes in one direction only. If there is any grit left on the car after washing, the blade may pick it up and drag it across the paint, much the same as a towel would, this can be avoided by wiping the blade with a clean damp towel after every pass.
The water blade should be protected when not in use. If it is crushed in storage, the edge may take a set and leave a stripe of water on the car, the water blade comes with a protective plastic case, use it for blade storage.
Like any tool, the water blade does require a little bit of technique and practice. The first few times I used mine, it tended to chatter on the surface, resulting in incomplete drying. It turns out this is eliminated by using just the right angle and pressure on the blade. Smoothness can also be affected by the surface condition of the paint (wax, sealant oxidation, etc.) and any coating that might be on the water blade itself.
Caution: do not use- a water blade to remove rainwater as there could be road grit on the paint surface or the rain may contain impurities that could scratch the paint.
JonM
JonM
What do you use then to remove rain water?
JonM
JonM
I used to use one till I scratched the hood on my truck with it. I did it real good too... from the cowl to the grill on the hood. I was wiping it on my pants to clean it.... what an idiot I am!
