- A Thank You From Tadge
- C7 Grand sport Hp. and Torque.
- OEM tow hook
- Will there be a screen update?
- Over the Air Updates for C8
- Reliability & Quality Control
- paint colors
- Towing
- Potential "60th" Anniversary Z06 Production?
- changing out engine support bars
- Upgrade for 2021 or 2022 C8
- magnesium
- Ackerman Steering
- C8 cooling for NON Z51 cars
- Wireless apple play on 2020 - Can it be converted?
- Slowest speed for full clutch engagement?
- Elevated engine heat directly beneath the stowed convertible roof
- Gift from GM on the new C8
- Loud turn signal indicator
- Red Mist 2021 color
- Quality Engineering Hold
- Hood... C5-C7, Maybe C8+
- NCM recent video presentation
- Z-51 All Season Tire Option
- No Adaptive Cruise Control
- Sill Plates
- C7 TPMS speed limited
- Mag shocks for C8
- C8 radio knob should move
- C8 paint peeling on front and rear bumpers - Same as C7 - What's being done?
- Big-Lid Bricks
- C8 rear cabin window
- What is being done to investigate frunk opening at speed?
- Honeycomb Screen for Front Intakes?
- How similar is the final C8 design to the ME design that was supposed to be the C7?
- [ANSWERED] C8 Z51 Package and Transmission Fill
- Launch control c8
- Corvette tool kit.
- Authorized Corvette dealers
- [ASKED] Brake Fade Warning System
- [ASKED] C8 Z51 Package and Transmission Fill
- C8 removable roof
- Repairing Carbon Fiber Hoods
- [ANSWERED] Change in lug nut size and wheel torque
- [ANSWERED] Warranty coverage for non-Z51 C8s during HPDEs
- [ASKED] Change in lug nut size and wheel torque
- C8 stylists
- C8 Convertible Rollover Protection
- C8 Production
- Will changing the unsprung mass hurt the handling
- C8 Octane Requirement
- Customer Request for Blind Spot detector Audible Alarm
- [ANSWERED] What's the Corvette Team Process for Continuous Improvement & TQM?
- What maintenance requires dropping the engine / transaxle?
- C-8 Build Time.
- [ASKED] Warranty coverage for non-Z51 C8s during HPDEs
- C8 track sound limit
- [ANSWERED] C8 Z51 Cooling Question
- Red Stiching
- jacking the C8 up on along the sides, or front/rear
- C8 Brake pad question
- C8 production
- Mobil 1 ESP.. vs non-ESP forumation
- C8 Owners manual
- [ASKED] What's the Corvette Team Process for Continuous Improvement & TQM?
- C8R Certification to racing bodies
- [ANSWERED] C8: Reduced Torque During Drivetrain Break-In
- Now that C7 has ended, can you tell us about the car in this spy shot?
- Why was the C5 DIC Code Reader done away with in all subsequent generations?
- Popping And Gurgling On Decel In A C7 With Npp Exhaust
- Aggressive street alignment C8
- [ASKED] C8: Reduced Torque During Drivetrain Break-In
- High wing drag ?
- [ANSWERED] Will the C8 be running in AFM mode by default?
- Will the C8 fix warble noise?
- C8
- [ANSWERED] C8 Development Process - The "Ah HA!" Moment?
- High wing spoiler
- What's up with the number 51 for the z-51?
- [ASKED] C8 Z51 Cooling Question
- Question of oil level for C7 Z06, ZR1, Z51
- Shift Time in milliseconds of the Tremec DCT?
- [ASKED] Will the C8 be running in AFM mode by default?
- High wing
- C8 will there be a paint to sample program PTS -
- Finding the right service department
- [ASKED] C8 Development Process - The "Ah HA!" Moment?
- C8 looks without a rear spolier...so much better. Delete option for the Z51?
- C8 DCT Programming Clutch wear
- StabiliTrak. C7 vs C8
- Transparent Roof
- C8 wheel offsets
- C7 vs C8 select mode
- C8 Base vs Z51
- C8
- Options for C8
- Performance exhaust clarification
- Lift system made automatic?
- C8 StingRay / Start Stop feature
- What engine reliability testing procedures do you run
- Inner/outer spokes on C8 wheels?
- C8 Wheels
- MRC question on C8
- Air flow through the C8's engine compartment
- C8 performance exhaust
- C8 Side Marker Lights
- Spring design
- HUD adjustability 2019 Z06
- Asbestos
- C6 Clock/GPS
- LS stands for.... ?
- Why was weather mode discontinued?
- [ANSWERED] Why does GM reuse engine names for different engines (eg. LT1)?
- Lost time display on C6 Radio/NAV screen
- Factory tours, when?
- 2019 ZR1 A8 2nd Gear Issue
- [ANSWERED] fishtail to the RIGHT
- C7R wheels and tires
- Why No Customizable Throttle Settings?
- Upholstery Coming undone on Driver Side Seat left seat Bolster
- T1 Suspension Upgrade on Z51 with FE4 MSRC
- [ASKED] Why does GM reuse engine names for different engines (eg. LT1)?
- [ANSWERED] Clear up the oil confusion regarding aftermarket DEXOS 2?
- Valet Mode Limitations
- New catalytic converters and ESP Mobil 1
- Windshield
- Machined face wheels
- [ASKED] fishtail to the RIGHT
- [ANSWERED] C7, c7zo6 and c7zr1 manual tranmission and axles
- [ASKED] Clear up the oil confusion regarding aftermarket DEXOS 2?
- Body in white
- Visits to Corvette Engineering from legends/retirees
- [ANSWERED] Effects of front tire deflector on downforce
- Best Practice Recommendations for Winter Storage
- [ASKED] C7, c7zo6 and c7zr1 manual tranmission and axles
- [ANSWERED] Oil life monitor calibration same for dry and wet sump?
- Interesting Note
- [ASKED] Effects of front tire deflector on downforce
- [ANSWERED] Thoughts on Results of Best Driver's and Lightning Lap?
- Can Corvette offer a harness bar ?
- [ASKED] Oil life monitor calibration same for dry and wet sump?
- C8 Geometry
- [ASKED] Thoughts on Results of Best Driver's and Lightning Lap?
- Dry Sump Design Change
- Z51 Track Mode Mag Ride
- A8 Replacement
- [ANSWERED] Thoughts on C&D ZR1 vs GT2RS
- New Mobil 1 ATF Fluid
- Performance timer
- C7 carbon fiber protection against Lightning strikes
- SAE Tech papers on C7 Chassis
- why no update to the 3lt/3lz dash manufacturing?
- Apple Carplay wireless
- Are improved ZR1 Carbon-ceramic rotors and pads also shared with 2019+ GS/Z06 Z07?
- [ANSWERED] C7 Z06/ZR1 Transmission Fluid on Ground
- I want Rev Match set to on as the default in a M7
- [ASKED] C7 Z06/ZR1 Transmission Fluid on Ground
- [ANSWERED] Advancements of Taillight Technology
- RPM and oil pressure variations while in cruise control
- Wheel stagger tolerances for traction control and active handling
- Manual Gear Box In The C8 Mid Engine Corvette
- Column lock
- PDR enhancements and updates
- A8 Transmission
- [ANSWERED] Impact of leaving the ZR1 track cooling items installed on the street
- [ANSWERED] "Ice mode" in PTM driving modes
- [ASKED] Thoughts on C&D ZR1 vs GT2RS
- Ask Tadge Poll: Ending 7/8/18
- [ANSWERED] C6 ZR1/Z07 Rear Brake Rotor Discontinued?
- Ask Tadge Poll: Ending 6/24/18
- Why doesn't the hatch open?
- ZR1 carbon-ceramic BremboŽ brakes
- [ASKED] "Ice mode" in PTM driving modes
- MRC upgrade on a 2019 GS
- Ask Tadge Poll: Ending 5/27/18
- [ANSWERED] Conventional 5 lug nut wheels vs. forged center lock wheels
- Competition Mode - C5 vs C6
- [ANSWERED] Interior Design and Fabrication Standards
- [ASKED] C6 ZR1/Z07 Rear Brake Rotor Discontinued?
- [ASKED] Advancements of Taillight Technology
- Why no factory harness mounts?
- [ASKED] Impact of leaving the ZR1 track cooling items installed on the street
- Hindsight is 20/20 -- what would you change?
- Ask Tadge Poll: Ending 5/13/18
- [ASKED] Conventional 5 lug nut wheels vs. forged center lock wheels
- ZR1 Front Quarter Panel Design Changes
- Mid Engine
- Glitch after MRC Update
- Mike Thermos
- C7 Corvette Performance Intake (84152141)
- nurburgring
- [ANSWERED] ZR1 vs ZO6 exhaust system
- Balanced Downforce
- Ask Tadge Poll: Ending 4/29/18
- Fuel door idea...
- What exactly is happening when a C5 clutch pedal sticks to the floor?
- [ASKED] Interior Design and Fabrication Standards
- Ask Tadge Poll: Ending 4/15/18
- MR suspension upgrade not for europe ?
- Latest Magnetic Ride Suspension Software update
- 2019 zo6
- Why are dealerships not aware of 0W40 oil uses?
- [ANSWERED] C7 ZR1 - What components have been upgraded to hold the increased power?
- Warranty approved oils?
- Bushings on the Suspension System
- [ANSWERED] Engine Cavity and Wheel Cavity Air Management
- Update on this upgrade kit please
- Could we have a software update for dashboard improvements?
- C7 ZR1 Spring Rate Comparison
- Ask Tadge Poll: Ending 3/4/18
- [ASKED] C7 ZR1 - What components have been upgraded to hold the increased power?
- Year to year changes
- Safety spec for test / lap record C7's
- Ask Tadge Poll: Ending 2/18/18
- Will the newly released Magnetic Ride Performance Calibrations cover 2014s
- [ANSWERED] Why has there been four different torque converter part numbers released?
- Olm
- [ASKED] ZR1 vs ZO6 exhaust ststem
- 8L90 backwards compatibility with Gen IV?
- [ANSWERED] 17 z06 running on 91 octane
- Little Stuff
- Ask Tadge Poll: Ending 2/4/18
- Wheels: Corvette Z06 vs. Camaro ZL1
- [ANSWERED] New oil fill 0w40
- why no oil cooler ?
- [ASKED] Why has there been four different torque converter part numbers released?
- Ask Tadge Poll: Ending 1/21/18
- [ASKED] 17 z06 running on 91 octane
- Z07 vs ZR1 suspension and downforce
- Ask Tadge Poll: Ending 1/7/18
- [ANSWERED] Magnetic Ride Performance Calibrations
- C7 ZR1 Fuel System Specs
- Catch Cans
- [ASKED] New oil fill 0w40
- A8 paddle tuning
- Quality hold z - 06
- Painted panels for 2018
- Do Canadian Corvettes have the same engine tune?
- Update on A8
- [ANSWERED] Center console armrest and door panel foam indentations
- Ask Tadge Poll: Ending 12/10/17
- C7 ZR1: Pricing Announcement vs Dubai Quote
- [ASKED] Engine Cavity and Wheel Cavity Air Management
- New C7 ZR1: Brakes
- [ASKED] Magnetic Ride Performance Calibrations
- [ANSWERED] Aftermarket part influences on factory release models
- Ask Tadge Poll: Ending 11/12/17
- New C7 suspension calibration software for Magnetic shocks
- T1 suspension SCAM!
- [ASKED] Center console armrest and door panel foam indentations
