View Full Version : C1 & C2 Parts
- WTB (Want To Buy) 1963 Gauge Cluster Bezel
- WTB (Want To Buy) 1966 coupe rear window upper molding
- FS (For Sale) 3797902 Exhaust Manifold with Heat Riser
- FS (For Sale) Set of 4 Goodyear 670x15 black wall tires
- WTB (Want To Buy) 1966 Air Cleaner Lid
- FS (For Sale) GM OEM Corvette 1953 thru 1982 Parts & Illustration Catalog
- FS (For Sale) Corvette Road Race set NEW and sealed
- FS (For Sale) Tail Pipe Exhaust Bezels - Pair
- FS (For Sale) Rear License Plate Bezel - 1963 -1967
- FS (For Sale) Steering Wheel - Original - 1965 Corvette
- WTB (Want To Buy) A/C center louver
- WTB (Want To Buy) Flashers
- FS (For Sale) 1965 Center Arm Rest Bright Blue
- FS (For Sale) C2 Tailpipe Extensions
- FS (For Sale) C2 Clear Vinyl Floor Matts
- FS (For Sale) 1965 Antenna - Reproduction
- WTB (Want To Buy) 1960 corvette lid
- WTB (Want To Buy) Rear spring bolt 8 in.
- FS (For Sale) C2 Bright Blue Dash Pads - 1965
- FS (For Sale) C2 Front Fender Tips
- FS (For Sale) 1967 original GM LOF glass set M3 winshield M51 side & rear glss
- WTB (Want To Buy) IDIDIT Tilt Column For a 1967 Corvette
- FS (For Sale) Front lower bumper brackets
- FS (For Sale) 67 327
- FS (For Sale) Knock Off Wheels 15x6
- FS (For Sale) 62-67 327 HP finned harmonic balancer 3817173
- FS (For Sale) NOS 64-67 coupe windshield corner trim
- WTB (Want To Buy) Aluminum Valve cover with a PVC hole
- WTB (Want To Buy) 66 Exhaust bezel
- FS (For Sale) Intake Manifold
- WTB (Want To Buy) C2 327 1964 Distributor Shield Kit
- WTB (Want To Buy) Wtb 67 dash pads black gm
- WTB (Want To Buy) Used '67 engine wiring harness
- FS (For Sale) 56-60 Small step sill plates
- FS (For Sale) 1966 1967 Corvette L79 350hp 327 Holley Choke Thermostat Rod Assy NOS
- FS (For Sale) 1966 427 Emblems - NOS - GM - 3876425
- FS (For Sale) Vette/Chevy Owners Manual Glove Box Bag
- FS (For Sale) NOS Parts L79 camshafts builder parts SBC BBC
- FS (For Sale) 1958 Borg Warner T-10 4-speed Trans
- FS (For Sale) NOS 1960-1967 327 5 blade fan
- FS (For Sale) 1960-1967 327 %
- FS (For Sale) 1956-1959 Valve Covers, Staggered-Hole, 7-Fin, OEM
- FS (For Sale) 600 Holley w/ New Rebuild Kit
- FS (For Sale) Hei distributor
- FS (For Sale) 58-62 upper and lower grille mouldings
- FS (For Sale) C! NOS Parts - NICE!
- WTB (Want To Buy) wanted rear Frigidaire a/c plate
- FS (For Sale) NOS 1963-1967 coupe door (passenger) side W/S
- FS (For Sale) NOS #323 Tung SOL flasher
- FS (For Sale) Wooden Restoration Jig
- FS (For Sale) 1963-1967 corvette parts from my “closet” collection. These parts are all genui
- WTB (Want To Buy) 64/65 Turn Signal Flasher
- FS (For Sale) 1963-1966 Rag Joints NOS
- FS (For Sale) C2 Corvette Parts For Sale
- FS (For Sale) 1966 & 1967 big block radiator shroud OEM
- FS (For Sale) 1963-1967 coupe windshield weatherstrip
- WTB (Want To Buy) C1 gas tank cover
- WTB (Want To Buy) 65 battery access cover L/Side
- WTB (Want To Buy) 340 horse aluminum manifold
- WTB (Want To Buy) 54 side curtains.
- FS (For Sale) 1965 steering dampener
- FS (For Sale) 63-67 Headlight Main Drive Gear
- FS (For Sale) 1965 Gas Filler Lid
- WTB (Want To Buy) late 1963 repo batttery
- WTB (Want To Buy) Original set of Knock Off Spinners
- FS (For Sale) 66-67 chrome door pull handles
- FS (For Sale) 1967 C2 Corvette Air Cleaner Base L-88
- WTB (Want To Buy) C2 Coupe pass. side, clear door glass
- WTB (Want To Buy) C2 Coupe windshied rubber seal NOS
- FS (For Sale) 1967 Tinted Front Windshield - Reproduction dated for DEC 1966 Build
- FS (For Sale) C2/C3 Corvette Removable cross Member Brackets
- FS (For Sale) 1964 Owners Manual
- WTB (Want To Buy) Marlboro Maroon paint
- WTB (Want To Buy) C2 Power Window Conduit
- FS (For Sale) 64/65 Turn signal flasher
- WTB (Want To Buy) 3756519 block
- FS (For Sale) 396 parts
- FS (For Sale) Pinion Yoke
- FS (For Sale) Water Pump Pulley 3850680
- FS (For Sale) Crank Pulley 3744043
- FS (For Sale) Differential Housing Stamped AM 6/23/67
- FS (For Sale) 4.56:1 Ring and Pinion
- FS (For Sale) 1958 - 1965 Small Block Exhaust Manifolds 3747038 & 3749965 exhaust manifoldS
- FS (For Sale) C2 Small Block Exhaust Manifolds 3797901& 3797902. 2 1/2 inch Outlet Ports
- FS (For Sale) 63-67 Rare NOS Tie Rods
- WTB (Want To Buy) 3789812 "P" differential case gear section, chunk, pig, etc.
- WTB (Want To Buy) September 1964 original stamped HH /365 hp block
- FS (For Sale) 67 68 69 Tri power blocks and carb fuel lines
- FS (For Sale) C1 Dash Insert Assembly Black letter 1959
- FS (For Sale) 1110891 Distributor NOS
- FS (For Sale) Mid year parts
- WTB (Want To Buy) WTB High-Quality Headlight Door Switch
- FS (For Sale) Small parts lot
- FS (For Sale) NOS rear cross member GM 56-62 part# 3744337
- FS (For Sale) C1 Corvette Art Morrison Chassis - $29,500
- WTB (Want To Buy) FI distributor mainshaft GEAR
- FS (For Sale) Original 1963 Trap Door Oil Pan Hi Perf
- FS (For Sale) Chrome BBC Valve Covers
- FS (For Sale) 1965 Dash cluster for parts or redo 250 plus ship
- WTB (Want To Buy) Owners Pin and Folder Info
- WTB (Want To Buy) spare tire
- WTB (Want To Buy) Hoist for hardtop
- WTB (Want To Buy) Package Tray and Support for 1960
- WTB (Want To Buy) 67 351 block
- WTB (Want To Buy) One Or Two 1963 Front Brake Drums
- WTB (Want To Buy) Hard Top for 64 Convertible
- WTB (Want To Buy) C2 roadster shop chassis
- FS (For Sale) 1966 Owners Manual
- FS (For Sale) C1 eyebrow grill moldings
- FS (For Sale) 1961 corvette 283 315 horse fuel injected
- WTB (Want To Buy) 775x15 bias ply gold line
- WTB (Want To Buy) 1956 Clock
- FS (For Sale) 2014-2015 Z28 , LS7 exhaust manifolds $750 plus ride
- WTB (Want To Buy) 1959 Seat frame
- FS (For Sale) 1965 or 1966 Hub Cap Set & Steel Wheel Set
- FS (For Sale) Convertible Vent Window Housing Pair LH & RH
- FS (For Sale) Rochester Fuel Injection Plenum Lid
- WTB (Want To Buy) 1956 headlight buckets
- FS (For Sale) 63'64 336 gears
- FS (For Sale) 63 rear end housing
- FS (For Sale) 63' 64 pinion flange
- FS (For Sale) rear axle heavy duty side yoke
- WTB (Want To Buy) Coupe vent window part
- FS (For Sale) 1965-1982 Corvette C2-C3 Park Brake Kit Stainless Steel X4229
- FS (For Sale) 1967 DC Master Cylinder 3/67
- FS (For Sale) 3890490 intake manifold
- WTB (Want To Buy) A Set of Rebound Straps/Hardware for 1960
- FS (For Sale) 1966 C2 Corvette Knock-Off Wheel Set Replica Style - Complete
- FS (For Sale) 1963-1964 C2 Corvette Knock-Off Wheel - Light Face Replica
- FS (For Sale) Inner windshield yrim convert
- FS (For Sale) 56-58 window stops
- FS (For Sale) Corvette books
- FS (For Sale) The Corvette complete restoration guide vol 1 53-62
- FS (For Sale) 1953, 54, 55 Corvette Triple Carb Complete Setup
- FS (For Sale) C1 tail light rivet tool
- FS (For Sale) 1958 Corvette owners manual
- FS (For Sale) TEAK STEERING WHEEL in Los Angeles
- FS (For Sale) 67 Original Gauges and matching clock restored
- FS (For Sale) C2 To me for a Spring Thread of parts for sale
- FS (For Sale) NOS GM 61 62 Corvette Off Road Carbon Steel Mufflers
- WTB (Want To Buy) Aero rivet tool
- FS (For Sale) 1963-79 C2-C3 Power Steering Rebuild Kit w/ New Control Valve & Cylinder Small Block
- FS (For Sale) Vintage Koni heavy-duty shock absorbers for '63 - '82
- FS (For Sale) 63-67 Rear 2.5" Stock Mufflers
- WTB (Want To Buy) 1963 June build 3461s AFB carb
- WTB (Want To Buy) deck lid side lock assembly
- FS (For Sale) Complete Corvette Restoration and Technical Guide Vol I
- FS (For Sale) 1954 Intake and Carter YH Carbs
- FS (For Sale) '63 250 Hp Air Cleaner, Carb, Intake and Upper Rad Hose
- WTB (Want To Buy) Drivers side vent window frame 1965
- FS (For Sale) Economy Chevrolet License Frame
- FS (For Sale) Corvette News directories
- FS (For Sale) C1 and C2 parts
- WTB (Want To Buy) 63 carter afb choke linkage
- FS (For Sale) AC 40083 Fuel Pump - 1 Generation AC Casting
- FS (For Sale) Art Morrison Chassis and 1958 Corvette Project Car- $60K
- FS (For Sale) Classic Chambered Powerstick Vettepack Muffers 2.5
- FS (For Sale) NOS 61 62 Corvette Front Bumpers (Pair)
- FS (For Sale) Deleting old for sale posts
- FS (For Sale) 64 65 66 Standard steering column nice shape! $325
- FS (For Sale) 67 Original Speed Warning Buzzer & Harness
- FS (For Sale) 7.75-15 Firestone Deluxe Champion Non DOT Tire
- FS (For Sale) 1963 Gauge Cluster 340-360hp
- WTB (Want To Buy) 67 Power Brake Master Cylinder
- FS (For Sale) Mid year interior day/night mirror
- FS (For Sale) 1963 Parts
- FS (For Sale) NOS 63-67 Bumper - Front Passenger
- WTB (Want To Buy) Non-DOT redline tire for '67
- FS (For Sale) Chrome Roll Bar
- FS (For Sale) 1965 Big Block original Hood & NOS Skin.
- FS (For Sale) 1965 396 962 blocks(two) for sale
- FS (For Sale) 1957 Corvette Seat Belt Buckles
- FS (For Sale) 1961 Posi Rear Drum To Drum 3789812
- FS (For Sale) 091 Delco Coil Original
- FS (For Sale) SOLD Detroit Speed Headlight Kit and Wiper Motor Kit
- FS (For Sale) Advice for selling parts
- FS (For Sale) NOS Parts! C1 + C2
- FS (For Sale) NEW (4) 15x6 Chevy Rally Wheels | 5x4.75" bolt | 4.00" backspace | Powder Coated Silv
- WTB (Want To Buy) WTB 67 427 PG L68 Center Carb
- FS (For Sale) 1967 Corvette Door Sill Plate Pair (OEM)
- WTB (Want To Buy) Rizz57
- WTB (Want To Buy) C2 headlight pivots
- WTB (Want To Buy) 1963 to 66 clutch and brake pedal housing. 1967 clutch brake pedal housing
- FS (For Sale) 1967 NOS smog pump, valves, hoses
- WTB (Want To Buy) 67 Frame
- WTB (Want To Buy) shock mount
- WTB (Want To Buy) Heater Y-Duct
- WTB (Want To Buy) original 63 master cylinder for a mid April car.
- WTB (Want To Buy) 63 Red Steering Wheel
- WTB (Want To Buy) Body Rotisserie
- FS (For Sale) 65 and up new trailing arm assemble’s lf and right
- FS (For Sale) 65-66 replacement frame with front susp.
- FS (For Sale) Rag Joint 64 65 66
- FS (For Sale) Dash Insert Assembly
- FS (For Sale) 1963-1967 mnual window regulators original
- FS (For Sale) Original GM trailing arms (left and right) for 1965 -1982 Corvette
- FS (For Sale) 1966-1967 alternator bracket like new
- WTB (Want To Buy) Wtb 67 black drivers dash pad gm
- WTB (Want To Buy) C1 Generator Volatage Regulator - non working
- FS (For Sale) 2.5 in exhaust manifolds
- WTB (Want To Buy) 65-67 Clock
- WTB (Want To Buy) 64/65 Rear Valance - Exhaust Version
- FS (For Sale) C1 Speedometer chrome trim 58-62
- FS (For Sale) C1 grille tooth # 424
- FS (For Sale) C1 58-62 Grab Bar chrome trim
- WTB (Want To Buy) 65 Corvette ignition switch
- FS (For Sale) 63 rear diff
- FS (For Sale) Parts Catalog and Illustration Catalog 1953-1979
- FS (For Sale) Rare 1966 C2 Corvette 427 engine block and parts.
- FS (For Sale) 56-61 Fender Stainless
- FS (For Sale) Brake Pads Original BENDIX Riveted Asbestos Pads
- FS (For Sale) C2 door cover plates ,vents and misc,,
- FS (For Sale) Show Condition Restored Original 1967 Corvette Rally Wheels (DC, GM, and KH stamping)
- FS (For Sale) 1963-64 Kock Off Sheels for sale
- FS (For Sale) Assorted Parts
- FS (For Sale) The Complete Restoration Guide-Noland Adams
- FS (For Sale) C1 58-61 Armrests
- WTB (Want To Buy) 1964-1967 shifter console
- FS (For Sale) 1953-1962 c1 corvette steering knuckle arms, pair
- FS (For Sale) 67 roadster complete original interior, Bright Blue
- WTB (Want To Buy) 67 Back Up Light Assemblies
- FS (For Sale) 64 65 66 Steering column & rag joint Survivor type excel cond.
- WTB (Want To Buy) 63 lower half rag joint housing
- WTB (Want To Buy) 4346 fuel pump
- FS (For Sale) Tinted Coupe Vent Glass Passangers Only - Dated VA
- FS (For Sale) Steering column & rag joint 64 65 66 Survivor type excel cond.
- FS (For Sale) 1966 327 350HP L79 NOS GM camshaft 3863151
- FS (For Sale) 58-61 C1 Side Fender Spear Set
- FS (For Sale) 53-62Folding top cover weatherstrip
- FS (For Sale) C2 68-69 Parking lights complete
- FS (For Sale) 64-67 gauge lenses
- FS (For Sale) 53-67 Outside mirror
- FS (For Sale) 1967 voltage regulator 7C rebuilt and restored
- FS (For Sale) 1966 Set of 4 Used OEM Hubcaps
- FS (For Sale) C1 cuff links and GM owner packet flyer
- WTB (Want To Buy) Assembly Line Hardware & Manufacturers’ Insignias
- FS (For Sale) Mallory tach drive distributor
- FS (For Sale) 1965-1967 type 3 jack
- WTB (Want To Buy) 1967 original rag joint
- FS (For Sale) 1953-1955 Corvette 6 Cylinder complete Carb Setup
- WTB (Want To Buy) C1 antenna
- WTB (Want To Buy) 65 / 365 parts
- FS (For Sale) Set Of Used OEM '63-'67 Taillamps
- WTB (Want To Buy) Wtb: 63-66 hood release cable bracket - w/ air conditioning
- WTB (Want To Buy) 1967 Corvette Wiper Motor
- WTB (Want To Buy) Lower Shift Boot
- WTB (Want To Buy) 1967 powerglide neutral safety switch
- WTB (Want To Buy) 67 Bolt-on Starburst centers & caps
