PDA
View Full Version : C5 Forced Induction/Nitrous
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149
  1. Catalyst Sims for Readiness Monitor?
  2. Rsd
  3. C5 Quick Spool Twin Turbo
  4. Trunk Tank ideas
  5. Supercharger questions
  6. Bringin Back the Twins
  7. Procharger fitment
  8. AA supercharger
  9. Supercharger vs. H/C/I
  10. Hoosier 46950R7 or Toyo R88R
  11. Issue on install engine by the top (mn6)
  12. Co2 kits vs Air Tank Pump
  13. Your One Stop Corvette Shop!
  14. intake for boosted ls2 ??
  15. Prep for supercharging
  16. Nos 15972 ??
  17. Oil ingestion issues and the proper way to address them
  18. Supercharger Sale! A&A, Magnuson,ECS, Procharger, Edelbrock.. 2YR 0% Financing!
  19. Is supercharging at 80k miles a smart idea?
  20. ECS 1500 Pulley/Belt Size
  21. TT - catch can, or air/oil separator?
  22. 2 more lbs of boost. 3 Hp increase
  23. C6 ZR1 intercooler
  24. 1 BRAND "NEWSED" SUPERCHARGER SYSTEM $1500 off!
  25. Brakes for your Corvette - KNS Brakes
  26. Anyone using a front splitter with your supercharger
  27. TPS Motorsports END OF YEAR SALE !! ECS TUNER KITS AS LOW AS $4899.99
  28. A&A V3 Si Install with Dewitts Cut Down Radiator
  29. New HP Numbers - ECS/Stock Block and Heads
  30. charge tube blowing off
  31. methanol tank
  32. Big 3 or Corsa Extreme for best perf.
  33. E85 flex or alky methanol
  34. Engine Build For 800whp supercharged
  35. Is boost by gear necessary? If you can retard the timing to accomplish the same thing
  36. 1964 A100 with an LS and C5 running gear. 1000+ hours and 1 year to this point.
  37. Huron - which hinson mounts?
  38. Cyber Monday Deals-A&A/ECS Superchargers-$5399, Procharger & AWE-15% off, and more...
  39. ECS black Friday sales 2023 are in full effect until December 1st!!
  40. Black Friday Deals-15% off Superchargers, 50% off wheels, & more...
  41. It's alot like Christmas
  42. BLACK FRIDAY SALE is ON! $600 off.
  43. A&A's Answer to the Squeaky Secondary Drive ?
  44. LPE TT Setup / Upgrades
  45. Pulley size and fuel system suggestions
  46. AC belt size for A&A IW Balancer
  47. advise on C5 z06 build
  48. Catch can rubbing on fuel rail cover
  49. TPS Motorsports Brake Upgrades as low as $325.95
  50. TPS Motorsports Suspsension Packages as low as $499.99
  51. Serpentine Belt Change - LS3 w/A&A Kit
  52. Weld laguna beadlocks 18x10.5 r / 18x5 f (c5, c6, c7 narrow body)$2195
  53. BTR stage 1 or stage 2 blower cam
  54. Boost a muv huron TT kit
  55. Rear Turbo + Keep the Tub?
  56. Need some input on my v1 s trim setup
  57. Single Turbo Kit
  58. Which LS2 TB
  59. 340lph "jet pump" options
  60. C5 FRC w/ A&A Supercharger by TPS Motorsports
  61. Thanks A&A Corvette
  62. Gained 8+ whp w/ Corsa Extreme & new plugs
  63. Fuel Pressure under boost
  64. Yank SS4000 and nitrous
  65. East Coast Supercharging
  66. belt tension
  67. Crankcase Venting
  68. flex kit
  69. This weeks builds at ECS, forced induction for C5/C6/C7 & C8 Every gen we service!!!!
  70. Best Oil
  71. Boost gauge / sensor for magnuson. which one?
  72. Nitrous set up
  73. Water Meth Mr Freeze or ?
  74. Does this boost sweep seem alright?
  75. Aftermarket filter/regulator noise
  76. FFS 04 fuels system
  77. Performance radiator for supercharged application
  78. d1x install and tuning
  79. 1000hp supercharger options
  80. Who is running a magnuson ?
  81. What supercharger to get?
  82. Vortech V3 Oil Dipstick
  83. Tire sizing question - FI guys opinion wanted
  84. aftermarket intake for magnuson supercharged 01 c5?
  85. A&A Supercharger Kit
  86. Swap LS1 for 5.3 ?
  87. v2 and oil pressure
  88. How to pass emission in CO - supercharger
  89. C5 forced induction / nitrous
  90. 04 fuel system
  91. stock super charger + tune then bolt ons ?
  92. C5 auto with Magnuson , do I need a tune or I mean does it run better with a tune?
  93. Novi Procharger Size
  94. Custom fuel system all the sudden won't hold fuel pump prime pressure.
  95. Supercharged ls1 c5. Small spray? Big spray?
  96. Supercharger Sale! A&A, Magnuson,ECS, Procharger, Edelbrock.. 2YR 0% Financing!
  97. Pulley down for AA supercharger SI trim
  98. Feedback requested - quote for upgrades
  99. Converter for ysi/auto
  100. 394 ysi w/ 2.85”
  101. Meth and Fuel Questions for P1SC C5Z
  102. 97-98 fuel rails and e85 - what's the HP limit?
  103. Memorial Day Sale-Superchargers, exhaust, suspensions, up to 20% off
  104. Need some help/guidance regarding tt (1999)
  105. 2nd brand new fuel filter, pressure is still too high
  106. Help identify this blower
  107. Used A&A kit price?
  108. First C5 Need Help
  109. Nitrous Tune and daily driving
  110. A&A Procharger for 00' C5 6spd, stock heads/bottom end/cam
  111. Vacuum Block?
  112. Interested in supercharging
  113. Leaded race fuel in nitrous stand alone tank?
  114. Those of you with add on external fuel systems how does your fuel pressure act?
  115. What rear gears for 700whp (suggestions)
  116. New Member Z06 Twin Precision 5862s
  117. Installed ECS 8an fuel block on early C5 and now I have no fuel pressure!
  118. Front license plate opening for intercooler
  119. Stock rockers. Keep ‘em?
  120. Boosted 1999 questions (map sensor/flexfuel)
  121. Need switch back from FI to NA, need advice
  122. Magnacharger for C5
  123. Pulley swap on my Vortech V3 for my C5
  124. 408 twin turbo cam help
  125. drilling the pan
  126. cam shaft for A&A V3 Si build
  127. Smaller diameter brake booster?
  128. Can someone please point me in the right direction for going with the Holly Dominator
  129. Atlanta Area A&A kit Install
  130. Methanol Question
  131. VALVE SPRING CLEARANCE SALE (PAC Racing / AFR / TFS)
  132. SC vs stock oil pressure?
  133. C5 early style pump options
  134. Dual in tank pump setup for early C5
  135. E85 Question
  136. Superchargers DSP Performance Motorsports has Them!!
  137. holley dual injector / dual fuel
  138. air water intercooler for c5 procharger d1x
  139. To wrap or not wrap my headers
  140. Intake for boost
  141. P59 Flex fuel enabled (Corvette OS)
  142. Christmas Sale-Twin Turbo Supercharger Headers, Wheels, Brakes, Wide Body Kit, & more
  143. LG BIG 3" Cat Back Exhaust - Your feedback ??
  144. Fuel Tank Venting Question
  145. ecs catch can
  146. Racetronix 255 lph in tank pump
  147. just what I needed, another project!
  148. TPS Black Friday Sale-Coilovers/Headers/Supercharger/Body Kit/Wheels & more...
  149. ATI Balancer
  150. Beginner aa procharger install
  151. New PB 8.3@163
  152. Best full Nitrous kit for 98 C5 Vette?
  153. Blow off Valve
  154. Cam Spec Options
  155. CAI under the hood vs Vararam CAI
  156. Wheel hop and knock retard
  157. Holley terminator dbw pedal install
  158. 99 c5 dyno sheet, car feels sluggish down low
  159. Boost + Fast intake
  160. snow performance meth kit
  161. TPS RPM Headers Inflation Buster Free Ceramic Coating $1199.99
  162. Arun jam Cam?????
  163. Disappointing numbers
  164. A&A oil dipstick stuck!!!!
  165. NEW MMS C5 Fuel Tank Tap
  166. Holley EFI Install
  167. Need tune file(s) please
  168. Block for 1K rwhp+
  169. Camaro Rick Does A Job : 500 RWHP Sleeper In Ten Minute Time Lapse. . .
  170. Introducing ECS' new direct drive system, NO NORE SQUELING BELTS- lost voltage @ WOT
  171. C6z A&A kit on c5
  172. Coil relocation problem?
  173. A&A Standard Intercooler Mounting
  174. Vancouver Island CANADA Buy
  175. Vancouver Island CANADA Buy
  176. 03 AE Procharger
  177. Magnuson or A&A for C5?
  178. Labor Day Sale-Superchargers, Headers, Monster Clutch, Wheels, Coilovers, Body Kits..
  179. Huron Speed Twin Turbo Kits - IN-STOCK!
  180. C5 Aftermarket ECU for Supercharger Tune
  181. Twin Turbo Install
  182. Heat exchanger coolant flow direction?
  183. Should I shim my pulley
  184. Supercharger belt
  185. Best way to clean debris from your C5 pro charger radiator?
  186. Run stock PCV Valve on 03 Corvette With Boost or the Check Valve Supplied from AA
  187. I want lower gears. Need testimonials
  188. Vortech V2 old school kit
  189. AA Corvette V3 Trim
  190. EgoKlr big single build
  191. Are you CA guys with A&A kits still passing SMOG?
  192. Maggie MP112 Oil Pressure Switch
  193. Suggestions on what to upgrade during A&A install
  194. Changed my meth usage.
  195. Still on the Fence...
  196. Heads with a procharger
  197. Oil cooler electric fan wired to cooling fan?
  198. Help me build a ysi long block
  199. Superchargers DSP Performance Motorsports has Them!!
  200. Anyone Regret Nitrous?
  201. ECS NOVI 1500 Boost Question
  202. TPS install A&A supercharger
  203. Mp112?
  204. injector/intake/fuel rail question
  205. Holly Low Impedance Injectors
  206. Ken Bell F/P install
  207. Where to find Methanol in Asheville, NC?
  208. This sucks..
  209. LSA Swap- first start check list - ideas?
  210. Erratic fuel pressure
  211. Mp112 pulley
  212. New SS Braided fuel line routing?
  213. Bottle Warmer?
  214. Aftermarket Rails with Firewall Clearance......
  215. 1998 C5 - ECS Built - Restoring?
  216. E85 / Flex on a 2004 with P59 wiring?
  217. Procharger Systems Now Available at DSP Performance Motorsports
  218. Stupid Newb Question
  219. Been awhile...
  220. Coolant Pressure sensor placement
  221. Haltech users, can you please verify coolant temp sensor calibration?
  222. VP Speed sauce vs 100% Meth
  223. bored
  224. Fuel needs with ECS kit
  225. Best forced induction LSX “Remote” tuner, Speed Density
  226. engine covers with magnuson
  227. Alky Meth Kit - MAP sensor question
  228. E85 fuel pump questions 800+hp
  229. Quest for 650 Crank HP
  230. In search of good tuner in DFW
  231. New build, 5.7 with t-trim and straight pump gas
  232. Is this enough fuel pump on E85?
  233. BOV placement
  234. Who's built their LS6?
  235. Alternator question
  236. Belt Type / Measurement
  237. Raceport bov with ysi 2.8
  238. Nitrous Basics
  239. Good old days
  240. tips for fixing ffx fuel cross over
  241. c5z nitrous conversion
  242. AA install
  243. Blower / PS res install
  244. ECS supercharger owners step inside
  245. Nitrous….maybe?
  246. setting pressure with an afpr
  247. Anyone successfully create an 8 rib belt setup using Summit Racing C2501 Balancer?
  248. Which performance driveshaft do I get?
  249. Methanol Debate
  250. faulty innovate motorsports gauge or boost leak?
