V710 Tire Pressure
Old 05-15-2006, 02:24 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Default V710 Tire Pressure
after seeing the V710s are WGI I decided that they would be a good tire to run on road courses. I am ordering them now, but wanted to know what has been the optimal hot tire pressure for the V710s and what is the starting psi to get me in the range.
My next track day is Pocono Long counter clockwise with the chicane and I thought this would be a good place to get some "trial' runs with them.
thanks
Old 05-15-2006, 02:29 PM
Maineiac
Maineiac's Avatar
Location: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
I ran them at 40psi hot, started around 31 cold.... I think.
Have fun at Pocono... I'm working on teh video, btw....it's currently 75MB I need to find a way to compress it or something...
Old 05-15-2006, 02:33 PM
Falcon
Falcon's Avatar
Maineac, convert it to .WMV. The quality isn't the best, but you can get ~2 mins in about 7 or 8 meg, just right for internet posting.
Old 05-15-2006, 02:45 PM
Wicked Weasel
Yeah you are the reason I am spending more money
BTW - cant wait to see the vid coming through the esses
Old 05-15-2006, 03:02 PM
danswofford
danswofford's Avatar
Default Tire Pressure
26 cold for me, they warm up to 34-35. I've been marking the edges with paint and they are not rounding over. I might drop a pound next time.
Old 05-15-2006, 03:10 PM
Wicked Weasel
reading more about these I see that the camber is -2 to -3. I am running -1.5 which I assume may lead to quicker wear. If so then these are not the tires for me.
Dam there are so many things to take into consideration.
Old 05-15-2006, 03:37 PM
Falcon
Falcon's Avatar
I run mine with -1.5 and have not had a problem with them cording, and I run them for a bunch of weekends. They will run out of grip before they cord, regardless of the camber.
Old 05-15-2006, 03:38 PM
Maineiac
Maineiac's Avatar
I did convert it to .wmv ....
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
hit the long course counterclockwise with NEPA
John Shiels
Old 05-15-2006, 03:41 PM
freefall
freefall's Avatar
There are many additional settings when compressing the video - mainly resolution and frames/second.
Jody - how many heat cycles are you getting out of your 710's?
Old 05-15-2006, 03:45 PM
Wicked Weasel
that makes me feel better
Old 05-15-2006, 04:14 PM
Falcon
Falcon's Avatar
John, I can get 6 weekends out of a set. That would convert to about 36 heat cycles, but after about 10 or so, they start getting greasy after just a couple of laps and only get worse from there. When I'm into the 6th weekend, their only purpose is to keep the car from scrapping the gravel, not to motivate me around the track, although they still have plenty of thread. I just threw 2 away this morning that had thread on them.
Maineiac, try clipping out just a couple of minutes instead of the whole tape.
Old 05-15-2006, 05:23 PM
95jersey
95jersey's Avatar
I ran V710 since the day they came out 2 years ago with -1.5 - 1.7, and got plenty of wear out of them. They have rolled edges which seem to tolerate camber challenged cars. That is actually in their marketing material. They did last longer and wore much better than say the Hoosiers for example under these conditions. With that said they will work better with -2.0
But again, I got several days out of them using -1.5
As far as temps...compared to other R's, they like to start out lower as they seem to rise more quickly than a Hoosier. Last week, I started them at 33F and 31R, and after 3 sessions I found the best starting pressure at 31F and 30R. I don't think they were near 40F. Even coming in from the track that is too hot for those tires, they will become greasy at that temp...vs the Hoosiers which won't even work until they are 40F.
Old 05-15-2006, 06:07 PM
Don Keefhardt
Don Keefhardt's Avatar
710's take significantly less pressure than Victoracers or Ecstas. We'd start 710's 10-20% lower than the other tires, and adjust accordingly. Rudy & Mike & Jay & the other Mike at Kumho confirmed that 710's were happier with lower pressures.
Awesome tire.
Old 05-15-2006, 06:19 PM
Maineiac
Maineiac's Avatar
It's a 5 min clip already....something is messed up. I'll have to redo it I guess...
Old 05-16-2006, 09:53 AM
wtknght1
wtknght1's Avatar
Most of the T1 guys are starting around 24 or so...and they warm up to mid 30s. We have about -3 in front and -1.5 in back. Just keep the hot pressures below 40 and you'll be fine. Those tires rock!!!!!
To V710 Tire Pressure
Old 05-16-2006, 11:05 AM
Wicked Weasel
Old 05-16-2006, 11:10 AM
yellow01
yellow01's Avatar
Wow that seems so low! Good to know though. My camber plates go in tonight after work, so we'll see what I can get out of 'em.
Old 05-17-2006, 09:46 AM
wtknght1
wtknght1's Avatar
That's with a full T1 kit too so your results may vary.
Get a good pressure gauge, pyrometer and a few open laps and keep playing with it until you find the right spot. As the old saying goes: "One good test session is worth 1000 opinions."
That's what I was really hoping to do down at Sebring helping Glen...but with the engine detonation.... oh well.
Quick Reply: V710 Tire Pressure
