Fear of oil starvation.
Old 05-17-2006, 12:29 AM
danswofford
danswofford's Avatar
Default Fear of oil starvation.
Accumulator or racing oil pan? That is the question.
Old 05-17-2006, 01:25 AM
67 fastback
67 fastback's Avatar
first thing that I did after ordering the car last week was to look into a canton pan
they don't have a part # for it yet.
I had a stock pan, a "t" pan with 2 trap doors, but I always lost presure on turn 3 of streets of willow.
the canton roadrace pan worked with out problems
I hope that someone makes a good pan for the c6
Old 05-17-2006, 01:39 AM
emf
emf's Avatar
Accusump. Worst case, you've got a pre-oiler, plus a safety net.
If you're pushing the car enough to where an extra 3 qts doesn't cut it . . . . dry sump.
(that's just IMO)
Old 05-17-2006, 07:10 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Accusump from DRM is what I run.
Old 05-17-2006, 08:00 AM
AU N EGL
AU N EGL's Avatar
First start off with an extra qt of oil. Use a race wt oil too. 10-w40, 15-w50, 40wt or 50wt
Then install an accusump and oil cooler.
Old 05-17-2006, 08:12 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
This an LS1/LS6/LS2 engine. While I'm not yet convinced, the LS2 pan seems to be a popular setup. Definitely use an accusump regardless. Not only do you get cornering protection, but you ELIMINATED dry start ups.
Remember the old Castrol ads. "90% of engine wear comes from engine startup", or something like that. It's nice having 20-30psi BEFORE you ever fire the engine.
Old 05-19-2006, 01:13 PM
danswofford
I've been looking at Canton road race pans. Anyone use them?
Dan
Old 05-21-2006, 01:58 PM
danswofford
2 qt. or 3 qt. accumulator? Canton or Moroso?
Old 05-21-2006, 06:44 PM
emf
emf's Avatar
3qt canton. Stuffs in the open area in the fender nicely.
Old 05-21-2006, 09:19 PM
danswofford
In the wheel opening? Above the tire?
Old 05-21-2006, 09:26 PM
emf
emf's Avatar
nope - driver's side, behind the wheel. Think roughly the spot where the battery/PCM is, only on the driver's side.
There's some pictures 'round here somewhere . . . I'll see if I can track them down.
Old 05-21-2006, 09:32 PM
emf
emf's Avatar
Hmmmm. Didn't find exactly what I was looking for, but this should help.
Old 05-22-2006, 01:30 AM
danswofford
The photo is helpful, thanks.
It seems like an accumulator is the concensus, however, my inclination is to get a real road race pan from Canton. Seems like the can is a bandaid and the pan is the real fix. Maybe both.
Dan
Old 05-22-2006, 02:00 AM
emf
emf's Avatar
IMO, it's a bit of both. For as good as the stock pan is, there's still some needed improvements. I'm personally not a fan of sheet metal pans . . . . but then again I've been called 'quirky' before as well.
Also IMO, for as good as any pan is, there's inevitably going to be a point w/ a wet sump where you'll be up a paddle w/o a creek. The bandaid is an extra 3 qts, at that point.
A dry sump is the real answer, regardless. Only question comes down to where you want to mount the tank.
Old 05-22-2006, 06:22 PM
ddl6289
ddl6289's Avatar
Default What is the canton number for an oil pan for C5?
I didn't realize that Canton Racing had a pan for the C5. Any info would be greatly appreciated.
thanks
To Fear of oil starvation.
Quick Reply: Fear of oil starvation.
