Lowering vs neg camber
Originally Posted by froggy47
How does lowering (with a flatter spring and or shim removal) on a c4 change the neg camber that you have already set?
TIA
TIA
Originally Posted by blkc6z51
Hey Bob, you can't lower that vette and run in AS
There ARE legal ways, I'll give you just ONE example. Let's say your oem spring fails (delamination - happens all the time). You could get a brand new spring from the dealer all curved & bouncy & fresh rubber bit's attached (I am assuming you know how the parts of the spring look & how it's made) or you could get a good used one out of a salvage yard with 175k miles on it......
