Flip Tires or Swap Wheels
Old 05-22-2006, 08:01 PM
Dirty Howie
Dirty Howie's Avatar
Default Flip Tires or Swap Wheels
Track I run (WSIR) wears outer edge of driver front tire. Both front tires are worn but still have some life left.
Do I need swap the two front tires?
.....or can I just swap the wheels at the track and run the tread backwards. Then swap back before leaving the track.
Tires are Nitto RII
Thanks,
DH
Old 05-22-2006, 08:10 PM
varkwso
varkwso's Avatar
Tires are Nitto RII
Thanks,
DH
Yes - I just did this last weekend with Sumitomos. It only matters if it rains - but then it never rains in Southern California so I remember...
Old 05-22-2006, 09:13 PM
joemoia
joemoia's Avatar
Howard,
Allan checked with Nitto, and its OK to run the tires with the tread backwards on a dry track.
Old 05-23-2006, 01:05 AM
Dirty Howie
DH
Old 05-23-2006, 01:10 AM
Dirty Howie
Originally Posted by joemoia
Howard,
Thanks Joe............I noticed after the SOW that its getting pretty thin on that outside front driver side tire.......and I'm hoping to put some hurt on that area at OT next week.
........so I guess you will see me doing the old wheel swapping bright and early
DH
Old 05-23-2006, 01:59 AM
joemoia
joemoia's Avatar
DH
Do you mean OTR next month?
Old 05-23-2006, 02:29 AM
emf
emf's Avatar
Howie, are you talking about flipping the tire inside to outside on the wheel, or just flipping wheels from side to side? Either way, doesn't really matter . . . the directional tread thats on the tires you're talking about are all for water egress . . . assuming no water, you can safely swap and never know the difference. If you're hardcore, you'll eventually end up swapping the tire inside to outside on the wheel . . . . just the thing for camber challenged cars, or too much shoulder wear.
Old 05-23-2006, 06:30 PM
Dirty Howie
Eric
These are my street and track tires......
I have gotten VERY EVEN wear on all 4. Just noticably more on that outside driver front. I have Z06 alignment. Probably I should just swap the front tires but got to find the time and its a waste of good BRAKE PAD money. I will just swap the wheel before first session and get some wear on that good passenger tire. Then swap back before leaving the track.
DH
Old 05-23-2006, 06:41 PM
Slalom4me
Slalom4me's Avatar
Doesn't reversing rotation cause the plies/cords/belts to be pulled
in a direction opposite to that in which they have taken a set?
I've got wear on the outsides of GY GS-C's which are directional
and side specific. I'm going to flip the tires on the wheels and
move the fronts to the rears: pass front will land on driver's
rear & ect - but all will continue to rotate and be loaded in the
direction in which they were in the past.
I expect to lose performance and to experience a bit of wiggle
because of the different wear characteristics fr/rr. But I'm of
the opinion that keeping the tires turning the same direction
reduces the likelyhood of internal separation or other damage.
Yes, no, maybe so ??
Old 05-23-2006, 07:39 PM
Dirty Howie
Oh Great ...... is this correct ????
DH
Old 05-23-2006, 09:44 PM
varkwso
varkwso's Avatar
No - unless the tire is broken down internally (bubbling usually seen)
Old 05-23-2006, 09:47 PM
steve-d
steve-d's Avatar
Just dial in more negative camber. Answers all probs and eliminates premature tire wear.
BTW, were your tire temps even when checked on pit lane or or what was the differential?
Steve
Old 05-23-2006, 10:28 PM
Dirty Howie
Steve
Tire temps were even.
......WSIR has TWO long right hand sweepers and only two short lefties.......it is a common wear problem seen at this track!!!
DH
Old 05-24-2006, 12:46 AM
StArrow68
StArrow68's Avatar
Howie, you gotta run more tracks! BW both directions, Sears Point CW, Laguna Seca CCW, makes for more even wear. Then you just get the tires remounted on opposite sides and get a whole new outside edge to abuse, or wear as the case may be.
BTW, five days at Reno-Fernley this month ....
Randy
Old 05-24-2006, 06:35 AM
varkwso
varkwso's Avatar
DH
And most other road courses...I see it all the time
I agree with StArrrow68 - you cannot run too many tracks...
Old 05-24-2006, 04:59 PM
Dirty Howie
Randy
I'm back at WSIR on 6/21
.......I will try running it CCW .....maybe no one will notice
DH
To Flip Tires or Swap Wheels
Quick Reply: Flip Tires or Swap Wheels
