Tires for OEM Thin spokes
Old 05-24-2006, 05:23 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Default Tires for OEM Thin spokes
My friend is just getting into road courses and wanted to use his thin spokes until he can decide if he likes this or not.
I looked around for OEM size tires that will fit the thin spokes and found the
Kumho ECSTA SPT
Kumho ECSTA MX
Is one better than the other (maybe RA1) - also does he have other choices???
Bob
Old 05-24-2006, 08:55 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,396 Likes on 748 Posts
I'm assuming he's wanting to stay with only one set of wheels. If that's the case, then I'd run the SPTs. Reason is that they're cheaper than the MXs, will serve him well on the street, and won't throw everything onto the paint during the 90+% of the time he's not racing.
Keep the tire pressures up and OE-level brake pads on the car, and he shouldn't have too much problems with them coming apart.
Now, if he's willing to go with a 2nd set of wheels, then I'd recommend the RA-1s. They're a great to-from set of tires, and I think they'll wear as good as or better than a set of street tires.
HTH, and have a good one,
Mike
Old 05-24-2006, 09:08 PM
Wicked Weasel
thanks - these will be track tires, but he will need to use them to and from the track.
He has another set of street tires.
He is also switching to Hawk Pads, but that is it.
Old 05-24-2006, 09:11 PM
VetteDrmr
VetteDrmr's Avatar
In that case, I'd go for either the MXs or RA-1s. One thing I thought about after my original post was the cost difference between the two; the RA-1s can be pricey.
Have a good one,
Mike
Old 05-24-2006, 09:22 PM
Wicked Weasel
Have a good one,
Mike
Old 05-24-2006, 09:25 PM
varkwso
varkwso's Avatar
I prefer the MXs....
Old 05-25-2006, 08:00 AM
Wicked Weasel
I saw the MXs in stock OEM sizes and not the RAs.
What are the biggest tires he can put on stock size wheels (F/R)?
Old 05-25-2006, 10:05 AM
undertaker
undertaker's Avatar
Location: ECS : WTF did you break now and HTF did you break it this time
RA1's size wise....
would a 235/40R17.....25.4 for an 8 inch wide rim
and a 275/35R18........25.6 for a 9.5 inch wide rim work?
obviously theyre' a lil off from factory.
Old 05-25-2006, 10:50 AM
95jersey
95jersey's Avatar
If he's never done an HPDE before, he doesn't need R compounds. As a matter of fact he should stay away from them for a while. MX's are fine and cheap. They are my street tire and I have used them on the track succesfully. Not as grippy as the C5 F1 tire, but about 90%.
Old 05-25-2006, 10:52 AM
Wicked Weasel
sounds like a good choice...
Old 05-26-2006, 02:51 PM
VetteDrmr
VetteDrmr's Avatar
I'm running 275/305 on wagon wheels.
Have a good one (and a great Memorial weekend!)
Mike
Old 05-27-2006, 07:48 AM
Gordy M
Gordy M's Avatar
If he wants a great handling tire and streetable look at the Falkin 615. He can run the 255/40x17 front and 275/35x15 rear. This keeps his ride height ratio correct and give him great traction tire that does well in the rain.
To Tires for OEM Thin spokes
Quick Reply: Tires for OEM Thin spokes
