Brake doodads
Brake doodads
I'm installing stainless steel caliper pistons and Carbotech 12/10s and I'm wondering if the "pad abutment shim" and the "anti rattle spring" have any function in a race car. '02 Z06 application.
Received 8,918 Likes
You will need the pad abutment shim since it protects the aluminum caliper from the pad backing plate which is made out of steel. The springs can be tossed. Danny Kellermeyer told me the ends of the pad backing plates should be filed smooth so they can glide across the abutment shim better. If you look closely at the backing plates you will see a sharp line all the way around the middle of the thin edge of the pad on most of the pads. The line comes from the stamping process when the backing plates are cut out of a piece of sheet steel. This is what needs to be filed smooth. You only need to file the end that will impact the abutment shim when the brakes are applied.
Bill
Bill
Bill
Bill
And what spring are you guys refering to ????
DH
The anti rattle spring is a little stamped sheet metal thing that is on the bottom of the abutment bracket. It doesn't seem to do much, just pressing slightly on the bottom tab of the pads.
On my Z06 2002 there was no shim behind the pads just this pad abutment shim which rides on the end tabs of the pads, which appears to allow the pads to squeeze smoothly.
Just a little story about the anti rattle spring. Our 1st tow vehicle was Jeep Grand Cherokee that didn't have them. The front brakes were replaced at least twice, but we only got once under warranty. Three years later when we were shopping for a new tow vehicle, the anti-rattle spings were back.
Man ..... I must be dense cause I still don't know what you guys are talking about. I Have changed rotors and just replaced pads last week so I thought I knew all the parts.
There is a bent metal piece that attatches to the pad backing to indicate by sound when the pad is low by contacting the inside of the rotor. BTW....I removed this....don't want rotors scratched and check pads before track days
There is a thin flat sheet metal that slips on the back of the pad and must be held in place with caliper grease
There is a copper or brass spring like fitting in the caliper bracket that the ears of brake pad slide in.
DH
DH
people are selling special heat resistent ones to try and protect the brake calipers and prevent fluid from boiling.
from rattling around in the bracket. But your brakes won't self destruct if you don't have it, so you can try leaving them out and see for yourself.
THANK YOU VERY MUCH !!!
Scraper, Backing Plate and Anti Rattle Spring
Others have said the backing plate is to help with brake squeel.
Never considered removing those Anti Rattle Springs.....I lube them!!!
DH
DH
I had been told that the "anti rattle" springs would try to hold or keep the pads from a "full release" with the caliper even if they were "lubed"?
I've been running a C4 in road race for 4 yrs but we didn't have the same style as the C5's.
Since I just built a C5 I removed them and so far no issues.
I agree that one needs to keep a very close eye on all brake components before each race.
