Fuel Cells for a C5
Fuel Cells for a C5
Are any of you running fuel cells in your C5's.
I need to upgrade to a fuel cell but really want to keep the same location if possible.
From speaking with a supplier I feel like I'm trying to invent them?
While I can understand the Pratt Miller cars ran two cells that were a custom build, I can't believe I'd be the only one asking.
Any Help?
Thks.
Any Help?
Thks.
Any Help?
Thks.
Any Help?
Thks.
Next on the list, FuelSafe bladders for the stock tanks. These will NOT pass tech since they're just bladders , and aren't skinned in alum. They do however, offer some additional protection and reuse much of the stock stuff.
Everything else that passes as a "fuel cell" installs as an inverted T at the back of the car, or otherwise sit 'on top' of the tranny and diff on the rear deck.
Bottom line, it'll depend on what tech you need to pass, what the need is, and how much you want to spend. Most race groups (NASA and SCCA) will accept the stock tanks (much like the Vipers) or otherwise grandfather the stock tanks for C5s under the same rules as WCGT.
Fuel Safe has not even answered any e-mail requests at this point.
Do you mean that the SCCA has allowed stock tanks in GT1? or with a "bladder" inside.
I'm in Canada and we come under CACC spec's but really these revert back to the SCCA rules for GT1 I think as we don't have any T1 classes.
If you have any other info or contacts from Fuel Safe I'll keep trying.
Thks.
Sorry but what is WCGT?
Thks.
Location: If you don't weigh in you don't wrestle Road America
I know that Melrose International sells a set-up for C5's, they also make headers and are a supporting vendor.
http://www.melroset-tops.com/race.htm#C-5%20Fuel%20Cell
You . . . may have a harder time in SCCA GT1, since the field is filled mostly with tube-frame cars and purpose-built cars (as the GCR puts it "highly modified replicas"). I haven't read the CACC GCR, so I'm not sure if the class is the same, or not.
I know that SCCA won't sign off on the Fuel Safe bladders since they do not meet the true definition of a "fuel cell" -- If they were skinned in aluminum, it'd be a different story. Most folk I've seen who need an actual cell in a street-based Vette have either custom made a cell, or used the inverted-T cell that Melrose sells.
I wasn't able to get any feedback from FuelSafe until I called -- IIRC, I talked to Howard to get the details on the C5 bladders, and what folk have done in similar cases.
Good luck
Good luck
Thks very much for the info.
Atl responded right away to the fisr request.
The issue is Pratt & Miller own the design so I need to go through them.
I'll keep Melrose in mind but I really don't want the fuel (read weight) back that far although it perhaps isn't much different than were it was with our C4.
Thks
Thks
