Remember when it was hard as a rock and firmer......
than a 6-inch piece of homogenous steel?
Well, the past couple of weekends have been like that for me.
Nope! There’s no Viagra or Cialis involved.
I finally used up my tapered brake pads and put some new ones on and the difference is shocking! I remember when they were like this, but ever so gradually, they just kept going down, and down, and down. It got so bad at times when I was blipping the throttle on a heel/toe downshift, I was blipping with the right side of my ankle.
Man, I wish I could afford new brake pads for every event.
Originally Posted by yellow01
Jealous!
I can't seem to get that new. What calipers/pads are using?
Some of that is flex in the caliper, right? Had the same problem with the stock calipers, C5 Z06 pads, and Motul, but the pedal would return by the time I got home (75 mile highway ride).
Jody - those are pictures I definitely did NOT want in my head.
I hear you about the tapering - keeps making me think about the Stoptech or Brembo packages.
I thought I had a bad master cylinder or caliper(s) on the FRC after two events at Roebling and one at Sebring. The pads (ZO6 ones I picked up from you) do not look too bad but you can really feel it in the pedal.
New pads and tires every event would be so nice...
And then the cycle starts again!
Keep in mind, my front Wilwood's last 5 or six weekends, but they're down to the backing plate by then.
