HELP!!! water leaking in my Z06, not your normal places.
brian, i had the same type thing in my 99frc. mine was from water getting past the weather stripping/seal at the upper rear corner of the window. i actually ended up having the problem on both sides of the car. check to see if you have a bit of water on the small ledge where your seatbelt comes up out of the plastic. this is how i finally found mine. i noticed that water spot and then saw it drained right down behind the plastic to the floor. that one spot was the only one visible.
this might not be it, but easy to find out. if it is wet there, dry it, get somebody to slowly pour some water out of a pitcher onto the spot where the rear of the window meets the car. start low and work your way up until you see the water leaking in.
jake
jake
