5pt harness latch
I assume you are talking about the old style pelican hook latch system, not the newer snap latches, which can only go together one way. Assuming your pelican hook is on the lap belt on the right side of your seat, you put the right shoulder harness clip over the tongue, then the submarine/crotch belt clip over the tongue, then the left shoulder harness clip over the tongue, then the left seat belt clip over the tongue, and then lock down the pelican hook. If your pelican hook is on the left lap belt, than start on the left side and reverse the order. Be sure to snug down the lap belts so they are down on your hips before you start taking up slack on the shoulder straps.
CI 4-5-6-7 Veteran
Found this pic online.
http://www.rv7-a.com/135_3538.jpg
Sounds about like the way I had it figured. Thanks!
