Z06/Z51 C5 Rear Spring the same?
I am buying a used rear spring to replace my broken one.
I have been told that possibly the standard rear spring for a manual car and the Z06 spring are the same, just the front was different.
Anyone know if this is right? The seller believed one of the two was the same.
Rear spring
I believe it's the other way around - the front Z51 spring and the front Z06 spring are the same. The rear springs are different.
Taken from the GM parts catalog:
2004 rear spring part numbers:
22179019 - MM6, FE1 suspension
22146323 - M30, FE1 suspension
22146646 - M30, FE3 (Z51) suspension
22179020 - MM6, FE3 (Z51) suspension
22146323 - FE4 (Z06) suspension
2004 fron spring part numbers:
15233397 - FE1, not F55 (real time damping)
22178748 - FE1, w/ F55 (real time damping)
15233396 - FE3 (Z51) and FE4 (Z06)
No they are not the same. The front springs are the same. From Jake Lathums web site: http://www.jakelatham.com/c5/misc/faq.shtml#2-1
"Springs and rates:
Springs keep the car off the ground, and reduce dive/squat during acceleration and braking, as well as controlling body roll. The stiffness goes Base/FE1 < Z51/FE3 < Z06/FE4, <T1
Here are some Spring P/N's, in case you are looking to upgrade:
- Z06 Front spring: 22178729
- Z06 Rear spring: 22188038
- Z51 Front spring: 22178729 (note: same as Z06)
- Z51 Rear spring: 22179020
- Base Front Spring: 22178728
- Base Rear Spring: 22179019
The Z06 rear spring is about 10% stiffer than the Z51 rear - numbers are not 100% known, since the information was not made easily available by GM. Z51 springs are a bit stiffer than F55 springs, which are, in turn, a bit stiffer than base C5 springs.
"Springs and rates:
Thanks...I might have to hunt for a spring now.
I need to get one ASAP. We put the car on the trailer using a hill to get the angles right. Without a hill there is no way to get it off unless I swap out the spring first.
