Fire extinquisher mount
Old 07-06-2006, 10:16 PM
V8 Juice
Support Corvetteforum!
V8 Juice's Avatar
Default Fire extinquisher mount
Looking for experience and suggestions on mounting Amerex 2.5 pound halon fire extinquisher in C6 with Shark bar; otherwise stock interior.
Thanks.
Old 07-07-2006, 12:57 AM
vettedan
vettedan's Avatar
Thanks.
Use the Vetteworks C6 extinguisher bracket (pn-C605). It fastens to the front two seat rails and can be installed or removed in seconds without tools. No modifications are necessary. It is constructed through a precision lazer machined process and are powder coated with a matt (flat) finish. It fits all C5 & C6 Z06's.
Gm is currently using this bracket on their C6 Corvette pace cars.
Old 07-07-2006, 02:18 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Dan's mount with the Amerex is the way to go. That is what I use. They are completely compatible with our seat mounts as well.
Old 07-07-2006, 11:01 AM
V8 Juice
V8 Juice's Avatar
"It fits all C5 & C6 Z06's.
Gm is currently using this bracket on their C6 Corvette pace cars."
Thanks guys, really appreciate the help. You refer to Z06 model; is the hardware the same on standard C6 model year 2006 coupe?
Old 07-07-2006, 12:30 PM
vettedan
vettedan's Avatar
Yes, The bracket fits all C6 Corvettes.
Dan
Old 07-07-2006, 05:10 PM
V8 Juice
V8 Juice's Avatar
Dan
Just ordered....first time customer...I'll let you know via email satisfaction. Thanks for the help.
To Fire extinquisher mount
Quick Reply: Fire extinquisher mount
