Opinion DTC-70/Wilwood H
St. Jude Donor '05-'08
Just looking to what people think about each brake pad.
I ordered both sets - long story but UPS lost my Wilwood order so I rushed to get DTC-70s Fedex to me just in case the Wilwoods did not make it in time for WGI. Now it looks like I might have a choice of which one to run and which one to either send back or use another day.
I wondering what the characteristics of both brakes are like. This is my first time running a "race" pad and it would be good to know what to expect.
thanks
thanks
thanks
thanks
Never used the Wilwoods, so I cannot comment.
MAKE SURE you have the high-temp brake fluid of your choice in your system when using high performance pads. You will generate a lot of heat which will boil the standard DOT-3 fluid.
Enjoy...
Frank Gonzalez
Try Carbotechs instead!!!!!!
I've run them both over the past year(s). The Wilwoods will most likely fade on you after about 10 laps. I kept having to pump my brake pedal to keep it from going too long. Once I switched, I had no issue.
I tested the DTC-70s at Road Atlanta head to head against the Carbotech XP12s. The Hawks (DTC) was better than the Wilwoods to be sure, but I run Carbotechs on my car. The Carbos stop at least as well as the Hawks and the dust isn't corrosive...and I get them at about 2/3 of the price.
Bottom line - if you haven't run the Carbotech pads yet, you're missing the boat...and 'emptying' your wallet.
Any chance you've compared against the Performance Friction compounds? I was very impressed with the PFC01s I ran recently... worked as well on the big heavy 'vette as the old Hawk blues worked on my 2400lb Pro7 car.
In LOVE with the Hawk DTC-70's , great initial bite, very consistant braking. I have never ran the Wilwoods, but I have tried to kill my DTC-70's on many,many occassions and have never been let down by them.
What can happen if you run a high friction front pad and not swap the rear accordingly you will shift the brake bias even farther forward which will put even more heat in the front. I currently run Wilwood C type front and Hawk HP+ in the rear with great success. I run autoparts store 450 degree F brake fluid and no issues of brake fluid boiling and I brake hard at every corner. Only heat I ever have to worry about is the oil temp.
I use Wilwood C type which are similar to H but with lower friction (not stock caliper) but have had no issue with fade the wilwoods are good to 1300 degrees. They have 3 track events on them and they work great and still alot of pad left.
thanks
thanks
Two advantages for me: better rotor wear(WIlwoods tend to make em go quick) and great stopping power on a linear spectrum.
DTC 70's are a great find!
Carbotechs don't have this problem. They use a ceramic compound which has less dust (and non corrosive) and the heat transfer to the fluid is much, much less.
The PFCs were just OK. A friend (racer) of mine (Phil Croyle) tried using the PFCs during the National race at Sebring in 05. He stuck with us for about 3 laps and then they faded out. The Carbotechs didn't and I walked away from him. He switched back to the Carbotechs on the next race (Moroso) and we had a great battle.
Oh, did I mention the Carbotechs are cheaper too!!!!!!!!! You just can't find a better pad for the money. Race tested baby!!!!!!!!!
Thanks Guys.
The DTC-70s came in first so we went with those. During the bedding process it was easy to see that I should go to the dentist and make sure my fillings are tight before hitting the track
I thought the Hawk HP+ were good - silly me. These can stop on a dime and give a nickel change.....
Brake Fluid - I just switched over to ATE Racing Blue. I assume that is good enough.
