Will 295's fit on a 9.5" rim?
I run 9.5 Z06 rims up front at the track. Usually, I buy 275's. I know the stock size is 265. I know you ain't fittin a 305 or higher "safely", but can I fit a 295 and still be within reasonable levels? I run 315's in the back on GS rims and figure a 295 might help balance out things and take away some understeer.
I would check out Kumho's web site, they have the rim width for each tire size for each tire type. For the V710 they list a 295/40R17 which is recomended for a rim width of 10.0 - 11.5 inches. Not sure if that is a hard limit or not...
Yeah, I see that as well. I can also see this not being a big deal for Autocross (SS). Even if the tires folds over a little or deforms in some way, you are not going over 90mph and usually don't have walls 2 feet away.
I would like to hear any road racers that have used this size on this rim. I am not worried about the 50mph corner as much as the 115 mph turn one at Pocono or the 160+ mph top speed I'll be hitting on the back strait. Tire issues become much more serious at those speeds.
Have a good one,
Mike
You can get a very very little bit of rubbing on the outside lip of the fender if you are lowered all the way on stock bolts with the Kumho 295's, assuming that you are at max negative camber (like all you can get with the stock adjustment), it is nothing to worry about... If you aren't running max negative camber they will rub more....
