What clutch is best for roadcourses in 500 rwhp C5 Z06
Old 07-17-2006, 11:46 PM
Dr Chill
Dr Chill's Avatar
Default What clutch is best for roadcourses in 500 rwhp C5 Z06
Replacing motor and will likely change clutch while it's out. Which clutch do you recommend? Should I just keep my LS6 clutch with 10,500 miles?
Old 07-18-2006, 01:11 AM
NJCRUISER
NJCRUISER's Avatar
If you are going to be running 500 hp, You had damn well better replace the clutch and not with a factory setup, now is that 500 to the rear wheels? If so, you are in a precarious position if you street drive it. I would recommend an Exedy product only because they have been race proven in C5's. Problem is I am only familiar with the single hyper and flywheel rated for 450 hp that was used in Grand Am by the Sunoco Powell Team in their C5's and CTSV's.
You may need a twin plate clutch and sometimes this is a pain if you street drive the car as it may chatter some. Engine Mods can cause clutch rattle when the clutch pedal is depressed by movement on the intermediate separator plate in some applications. This is normal, however, and comes with the territory of multi disc sytems.
Here's a C5 chart from Exedy:
http://exedyusa.com/products/PDF/Corvette.pdf
Old 07-18-2006, 09:14 AM
Red Gump
Red Gump's Avatar
haven't had any experience with others bill but the spec3+aluminum flywheel in mine seems to work well on the track. pita on street though, lot of chatter. not sure you'll be able to avoid chatter though.
Old 07-18-2006, 10:05 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Exedy twin is a great clutch. A little on the racing side but once you get the hang of them, they are easy to drive on the street.
Randy
Old 07-18-2006, 10:07 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
I've installed a Exedy single and it is pretty quiet, there is a little chatter when you launch and it's engaugement is quicker, but all in all it's not unbearable. He's done two track events with it (3 days at Gingerman and 3 days at Mid-Ohio) and the only differance is the launch.
Old 07-18-2006, 01:52 PM
AMERICANMUSL
AMERICANMUSL's Avatar
If not for the street, go with proven names like Quartermaster or Tilton(i.e.) carbon/carbon, twin)...I've learned the hard way...pricey but they last!
Old 07-18-2006, 02:51 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
i installed an exedy twin disc....i have 540 rwhp,have run 5 track event on slicks with no problems and drive it on the street...
427 dry sump..
johnny
Old 07-18-2006, 05:13 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Lot's of people are loving the Spec3+. I don't have near that HP, but the clutch is very streetable. Worth taking a look at.
Old 07-19-2006, 09:03 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I have been running the RPS clutch at 460 rwhp and dont have any issues with it. Actually the more I run it at the track the smoother it gets...
Old 07-19-2006, 10:53 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Hey Bill,
In our little group of guys I've seen problems with Spec 3, 3+, LS7 and Centerforce. Not to name names but you know who these belonged to, two different guys. None seemed to stand up to drag racing for long, which is much harder than tracking. The LS7 has been getting a beating in the C6 forum, mostly from Ranger and other drag racers who don't like it at all.
Mike Norris recommended a stock LS6 clutch to my H/C car and it was flawless. As a matter of fact, I can't think of anyone in our Challenge that has clutch problems with the stock LS6, except one sticking to the floor, but that was remedied by taking out the over center spring. Can't beat the price either.
When's that bad boy motor going to be done?
To What clutch is best for roadcourses in 500 rwhp C5 Z06
Quick Reply: What clutch is best for roadcourses in 500 rwhp C5 Z06
