Tire Wear: 6 Track Days on Michelin Pilot Sport Cups(pics)
Old 07-18-2006, 11:19 PM
BlaznZ06
BlaznZ06's Avatar
Default Tire Wear: 6 Track Days on Michelin Pilot Sport Cups(pics)
What do you see that I need to to get better tire wear?
Fronts at 30 lbs for track
Rears at 28 lbs
Front passenger side
Front driver side
Rear; wear is the same on both
Old 07-19-2006, 01:23 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
I would flip them on the rims. Not much else you can do. Track driving is hard on tires especially new ones. Hopefully, you switched them from side to side when going to the next HPDE.
Bill
Old 07-19-2006, 02:20 AM
Sidney004
Sidney004's Avatar
6 days X 2 hours with what looks to be 2.5/32nds left is pretty darn good. You should be able to take these tires down to the cords, which is probably another 4 events at this rate. What are your hot pressures? It looks like the outside edge is getting chamfered, which could be a camber or pressure issue. I would recommend dismounting the tires and remounting in the same orientation on the opposite side. I realize that Michelin touts a different compound is used on the inside and outside of the tire but I doubt you would notice the difference. I presume that that front and rear are different sizes. I would also recommend treating the tires with Traction V(which is what I use) to freshen them up.
Old 07-19-2006, 07:38 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Do you have any idea of the temps? They look like they did not get that hot. Mine after 3 sessions last week on a 125 degree track were running about 185 and looked alot less smooth than yours.
Old 07-19-2006, 08:36 AM
BlaznZ06
BlaznZ06's Avatar
Temps have not been taken.
Hot pressures; Front tire pressure has run as high as 38lbs and the rears to around 34-36.
If I need to a pyrometer can be in my future.
Help me out with what Traction V is..........tire conditioner(softener)?
Thanks everyone.
Old 07-19-2006, 08:53 AM
ghoffman
ghoffman's Avatar
It is a valuable to the point of being essential. Get the probe type.
Old 07-19-2006, 09:23 AM
UstaB-GS549
UstaB-GS549's Avatar
If you want to minimize the wear in the center of the tire, I think higher pressures will help. Running wide tires at lower pressures may be quicker, but the center of the tread has a tendency to buckle outward between ribs while cornering hard and creating "groove of doom".
BFG had a real problem with this 10 years ago witht the R1 tires. Guys were cording the tires in the center after just a day of track time. Solution was to go higher on pressures.
Old 07-19-2006, 11:22 AM
Sidney004
Sidney004's Avatar
Traction V is a tire softener/treatment applied for three days a few days prior to the event. It enhances grip(i.e speed) and with less rear wheelspin may enhance longevity. I have been using this on Hoosier GAC's and have not noticed any detrimental effect on wear, in fact just the opposite. You can but it at www.pegasusautoracing.com for $40; that is good tor treating 3 sets(or events.)
Old 07-19-2006, 11:32 AM
Timz06
Timz06's Avatar
Looks normal to me, tires wear out on track. 6 days is already a lot of time on one set of tires.
Old 07-19-2006, 12:42 PM
gkmccready
gkmccready's Avatar
That's because guys were running the BFG R1s with less than 20lbs of pressure. If you ran them at 29-32psi, or the recommended pressures, you never encountered GOD. Atleast for autocross that was the case; I ran the same 32psi on the track as I did at the autox and never had an issue with GOD after multiple sets of the R1s...
glen
Old 07-19-2006, 03:09 PM
BlaznZ06
BlaznZ06's Avatar
Thanks everyone
To Tire Wear: 6 Track Days on Michelin Pilot Sport Cups(pics)
Quick Reply: Tire Wear: 6 Track Days on Michelin Pilot Sport Cups(pics)
