race seat and air bag question
I recently installed a race seat in my '02 ZO6. It has a provision for the OE belt receptacle, so I can use the factory three point belt for occasional street driving. When I do this, I get no warning lights of any sort, but I want to be sure the airbag is functional, since I don't want to do any street driving without it. The factory seat has an electrical connection to the female belt receptacle which, I suppose, could be integrated with the air bag system. Switching seats is not really a problem, but I had intended on simply leaving the race seat in, since I don't drive it that much on the street. If anyone knows the answer, I would appreciate your help.
Unless the airbag indicator lamp is on while you are driving the air bag should be operational. Mine is on all the time, but I dont have the stock steering wheel and airbag.
Originally Posted by 95jersey
I have an 01, but I keep the electical connection for the actual belt clip in tact, and it works by shutting off the light when I put my seat belt on. You can disconnect the power seat without disconnecting the connection to the seat belt clip. I also mounted this clip onto the hardbar aluminum rails that I have my EVO connected to an have the upper portion mounted to my Hardbar harness bar. Everything works perfect and I have been through NJ state inspection.
I have the power seat wiring wrapped up laying on the floor, but I still have the wiring connector plugged into the seat belt clip that can be removed from the stock seat. So my belt light goes off when I click my stock seat belt in the clip.
I have never had any other lights come on or go off because of this. I don't see what the power seat controls have to do with the Airbag anyway.
