New World Challenge entrant needs your help.
Old 08-08-2006, 10:19 AM
Lawdogg
Lawdogg's Avatar
Default New World Challenge entrant needs your help.
My partner John Boos is entered to run his first World Challenge GT race at Road America on Aug. 20th. We are running a C5 Z06 carbon fiber bodied car as we couldn't afford to move up to the C6 body and motor. We are thrashing to get the car done and get some track time by the end of next weekend. Does anybody know of any open track availabilty in the upper midwest like Ill., Wisc., Iowa, Mn at the end of this week or this coming weekend?
Old 08-08-2006, 10:25 AM
TRAIL BOSS
TRAIL BOSS's Avatar
Lou's Racing Clinic Putnam Park????
Info Post: http://forums.corvetteforum.com/show....php?t=1456769
Old 08-08-2006, 10:40 AM
Cashmo
Cashmo's Avatar
Gingerman Raceway in South Haven Michigan might work.
"OPEN TRACK, Test and Tune, every Tuesday through Thursday 5:30pm - 8:30 pm, $60 per driver, some Fridays also apply. See details for more information. Novice, amateur and pro racers are welcome, see you soon!"
Jeff
Old 08-08-2006, 10:46 AM
vms4evr
vms4evr's Avatar
Take a look on Open Track Action. You can find events anywhere in the country. Click on the Schedules button on the left.
http://www.opentrackaction.com/
Good luck in your new adventure. We'll be watching
Graham
Old 08-08-2006, 10:52 AM
jasonberkeley
jasonberkeley's Avatar
There is an SCCA National at Grattan Michigan this weekend, and they are having an open test day on Friday.
Old 08-08-2006, 10:56 AM
SWCGT31
SWCGT31's Avatar
Lou's clinic on Friday at Putnam Park. As part of a Viperdays event they will be offering 2 hrs of track time on Saturday and another 2 hrs on Sunday. You can join the race group or run time trials. The track is one of my favorites. Very safe so you won't be risking your equipment unnecessarily. Viperdays is very friendly and extremely well run, with small groups and great instruction. And did I mention Lou will be there on Friday!
Good luck, see you at Elkhart,
www.viperdays.com
Old 08-08-2006, 11:08 AM
NoOne
NoOne's Avatar
I'm putting on a open track day at Grattan on Monday if your interested.
We can probably squeeze you in, someone always ends up dropping out last minute.
8 20 minute sessions, 8 hours, lunch, etc $150 for the day.
Old 08-08-2006, 11:17 AM
A.D.Malmquist
A.D.Malmquist's Avatar
There is a session this weekend at Blackhawk with the Chicago Audi group.... http://audichicago.org/
I know the spots are "full", but contact them and explain what's up.
I assume you are aware of the Thursday (17th) test day.
Old 08-08-2006, 11:21 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Good luck to you guys!!! I'll maybe see you guys out there.
Randy
Old 08-08-2006, 11:44 AM
Lawdogg
Lawdogg's Avatar
Thanks everyone for the leads. Hope to see several of you at Road America.
Old 08-08-2006, 11:58 AM
2000BSME
2000BSME's Avatar
nice links.
Old 08-08-2006, 06:32 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
[QUOTE=Rippied Z06]Thanks everyone for the leads. Hope to see several of you at Road America.[/QUOTE
Good Luck to both of you!
Old 08-08-2006, 07:59 PM
Rob Willis
Rob Willis's Avatar
http://www.trackschedule.com/sched.html
Old 08-09-2006, 07:25 AM
73-84 IMSA Widebody
73-84 IMSA Widebody's Avatar
Good luck to all you real racers, kick *** and take names
Old 08-09-2006, 09:10 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Your probably better off with the C5 these days. You can run 200lbs lighter AND no restrictor plate. Just make sure you're running the smaller ASA camshaft, not the one we used to run. Not that they are likely to check it anyway.
Old 08-09-2006, 01:12 PM
A.D.Malmquist
I have been thinking the same thing. As it stands now, the C5 should be one of the faster, straight line, cars. At R. America it should certainly help.
Btw, is the Boos car the old Farmer ride?
Old 08-09-2006, 01:27 PM
John Shiels
scratch built at DRM all new
To New World Challenge entrant needs your help.
Old 08-09-2006, 01:33 PM
davidfarmer
Actually, they'll have to carry REWARDS weight for their first race, so it won't be an advantage. As if I wasn't slow enough at Mid Ohio, the extra weight is killer for a new car.
Lou should consider jumping into a C5, if he still has one available. 200lbs less weight, larger intake (smaller TB, but still larger than the restrictor in the C6), but small camshaft. Still better power-to-weight overall, likely
Old 08-09-2006, 01:46 PM
A.D.Malmquist
You sure about them needing the extra weight? The PRR reads:
2.15.9: Following the third round, any driver entering their first race of the season in
that class shall carry an amount of weight equal to the highest amount carried in that
class at that race. Rookies, as defined by the PRR, as well as any driver (rookie or
otherwise) who has not won a race in any of the series listed in section 2.4.3.1 in the
five seasons preceding the current season, shall be exempt from this rule.
Old 08-09-2006, 01:52 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Wrong car, this statement is incorrect!
The car we built was for Ed Braswell, but will be at Road America.
John Boos and Ron have been working on their car off and on for some time. John is one hell of a driver so I can't wait to see how the race goes.
Good luck guys,
Randy
Quick Reply: New World Challenge entrant needs your help.
