Hoosiers VRL. What pressure?
My buddy just bought some used Hoosiers VRL and whats to know what HOT tire pressure should you run. He's going to Buttonwillow and drives a C6 Z06. He's been running Kumho V710's. The Hoosiers are 305/18 front. 335/18 rears. Not sure the of the height.
thanks.
Steve
thanks.
Steve
I run 38 HOT. Found that 40 hot was way to slippery.
So cold psi on HOT DAYS, 30 front 29 rear. On cold days 33 front 32 rear
VRLs as other Hoosers love lots of negative camber. especially since they have stiffer side walls the GASs. Same rubber compound but different side wall construction.
those are the same I run 18x305/30 front and 18x335/30 rear.
front -3* camber rear -2.25*
