Input on track tire size for zo6 rims??
Keep The Shiny Sine Up
i am going to mount some race tires on 2002 zo6 rims
and i am thinking of getting hoosier r6
my car has been lowered but only 5/8"
i dont know if that will make a big diffrence in clearance
any input will be great
thanks
thanks
Originally Posted by BMERETR
Ft 17 x 9.5
rear
18 x 10.5
rear
18 x 10.5
front Hoosier P295/35ZR-17 $267 ea
rear P295/30ZR-18 $267 EA
That is the biggest recommended tires for those rims. Both have 79.5" circumference. You may want to drop the nose a tad to keep rake in the car. Both have 10" tread Hoosiers seem to be wider than other brands. Clearance should be fine
You can see the specs on the Hoosier site www.hoosiertire.com
left column road race then to spec's then scroll down to DOT tires
Frank Gonzalez
Originally Posted by gonzalezfj
Actually, John, a lot of C5Z drivers (including me) run the Hoosier R6 315 in the rear. You need that extra rubber to get the power to the ground. YMMV.
Frank Gonzalez
Frank Gonzalez
Originally Posted by xsiveone
It's also going to give you more understeer than running 295's all around.
Frank Gonzalez
